Re: CEC Capacitors
Rhomanski,
Because I still struggle with understanding the purpose of capacitors and how / why to use them in circuits, could you please explain how capacitors affect sound in these systems? And how replacing them with new ones improve the sound?
CEC Capacitors
Re: CEC Capacitors
Most of the old ones came with good caps but they are getting old. It improves the sond a great deal to use good quality modern caps like Panasonics and Nichicons. Mostly I use Nichicon KL series low noise for the audio path and PW series for everywhere else. In a lot of the older gear they used big power caps to help with big bass pulls.
Peevey was always the cheaper garage band brand. Marschall was what the big guys used. I remember Ted Nugent had a ramp behind his stacks. At the beginning of a concert he would run up the ramp and jump in front of the amps and speakers. You couldn't see him until he was airborne and he would land playing.Leave a comment:
Re: CEC Capacitors
Maybe it was Newark. It was the one affiliated with Farnell's. I think they told me they were owned by Farnell's so that would be Newark I guess.
At any rate it was six years ago and I found only Epcos and Panasonic making a 77mm cap of that voltage and capacitance. The original was 80 volts but no one made an 80 volt in that diameter. I could have changed out the metal mounting ring but instead just bumped it up in voltage. The original was 95mm tall and the replacement was 100mm. It just barely fit. I couldn't find anyone that carried the Panasonic, I only found it, on the Panasonic website.
I just checked and found some that might work and they are only $50 to $80. I would be worried 105mm might be too tall and I wouldn't be able to get the top screwed down without a bulge. Maybe I could though. Luckily the ones I found then barely fit, but they do fit just fine. It's been six years since I overhauled it and it works fine and still sounds better than anything I have ever heard before. That's why it's my favorite amp. I have more that are almost as good but none as good.
http://www.digikey.com/products/en/c...=0&pageSize=25 .
Anyway, he had something he called a stack. I think it was an amp. But the controls he said were never right. He couldn't get good sound out of it and traded it to Josh for some other one. I can figure out what names they were. I remember Peevy, but I don't know if that was it. I remember Marshal, but I don't remember if that was it. I know I fixed an old amp of his not too long ago, something called a Pignose. The tubes needed replacing. There's a potentiometer that needs replacing as well, but this thing is old and I doubt I'd be able to find the same pot.
Do replacing the capacitors in those amps with high quality ones generally make them sound much better?Leave a comment:
Re: CEC Capacitors
http://www.mouser.com/ProductDetail/...lNsvGkkgnc0%3d
Who makes the 390uF 400Vs that you have? You're from another country, right? I bet that'd take a long time to get here. Things overseas almost always take forever. I'm from the states.Leave a comment:
Re: CEC Capacitors
These models don't have PFC, do they?
What the large caps do on the primary side is take the DC signal from the bridge rectifier and smooth it.
Yea they were Cornell Dubilier SLPX series, specifically these. They were for a project from mid-2011 that didn't come to fruition, so they were perfect for the Enermax.
No one's 100% certain whether Epcos is a reliable brand or not. Someone here claimed they were junk a long time ago... Someone will almost certainly correct this if it's innacurate, but large primary caps don't usually need to be replaced with as much vigilance as small secondary caps because they're only filtering very low frequency ripple, so they're not nearly as stressed.
The exception to this would be primaries with a PFC circuit, where the large caps then do filter high-frequency ripple..
The only complaint about these old Enermax PSUs is that the stand-by circuit gets very hot even when the PC is shut down. But that's been covered here on this forum in great length in other threads, and it's a project for another day.
What are you doing with your Enermax?
I still struggle very much with trying to understand capacitors. I think it's really one of the last few things I need to figure out before it all clicks and I can start making my own boards. I need to buy some hard covered books that will teach me stuff. Can you recommend any? I try using the internet to learn but every time I sit down at the PC, I get side track! I seem to learn best from actual printed books.
This isn't my Enermax. It's a customers. It was going back into his broken PC that he brought me to fix, but after we decided he wanted me to recap it, he made the decision that he was going to put it in his nicer system and take the PSU from the nicer system and put it in this broken HP (which, hopefully, won't be broken once the Enermax is recapped).
Do they talk about mods to fix that heat problem anywhere?Leave a comment:
Re: CEC Capacitors
http://www.digikey.com/products/en/c...=0&pageSize=25 .Leave a comment:
Re: CEC Capacitors
I'd say on par with japanese caps.
What about those 3300/16 D10, wanna? AFAIK nobody else carries those. And I also have some samples of 390/400Leave a comment:
Re: CEC Capacitors
I bought two Epcos caps for my favorite amplifier. It is 22,000 uF @ 100V, 77mm x100mm. Digikey had two varieties available one was $200 the other was $100. The specs and manufacturers part number was exactly the same. Digikey said the expensive was in stock, the cheaper was in stock at Farnell and I'd have to wait an extra week for customs. Mouser had them for $200. I bought two from Farnell through Digikey for $200 total. I'll wait a week to save $200. I've ended up buying quite a few parts from Farnell's, just outside London, because it was cheaper, even with shipping.
I wanted a 390uF 400V cap EPCOS for this PSU I'm rebuilding, although the Hitachi is fine. I thought that'd probably be the nicest cap I could put there. But I can't find any place that will sell just a single one. Mouser and Digikey don't have them in stock and I need to buy something like 240 of them if I want to place an order. I'm not familiar with Farnell. I just googled them and found a site called newark that has some but the wrong diameter.
Are those EPCOS really as good as some of the sites on the internet claim they are? The ones I were looking at had some sort of self-healing property, so if the dielectric dried up, they'd still work or something like that.Leave a comment:
Re: CEC Capacitors
Oh my, 100 bucks for a cap? You kidding me?
As for Enermax units, I have only seen some ancient ones here on photos without PFC (some AT maybe), everything else I've ever seen always had active, boost circuit.Leave a comment:
Re: CEC Capacitors
Also, when you say primary caps, are you talking those big giant ones? I thought they were called PFC Booster Caps and I thought there was generally only one. I haven't heard of Cornell Dubilier, but I haven't heard of a lot of capacitor manufacturer names. I ran across a company called EPCOS, and that had one that looked real nice, for the PFC Booster Cap, but I'm not replacing that one. I think the one in this is a Hitachi HP3. Those EPCOS ones I was looking at, they said they were self-healing and had a really long lifetime rating of 10,000 hours @ 85c. But I'd have to buy a minimum of 240 and they're around 6$ - 7.50$ a pop!!!! I couldn't purchase that many of them, but boy, would I love to find one of them somewheres.
What are you doing with your Enermax?Leave a comment:
Re: CEC Capacitors
I bought two Epcos caps for my favorite amplifier. It is 22,000 uF @ 100V, 77mm x100mm. Digikey had two varieties available one was $200 the other was $100. The specs and manufacturers part number was exactly the same. Digikey said the expensive was in stock, the cheaper was in stock at Farnell and I'd have to wait an extra week for customs. Mouser had them for $200. I bought two from Farnell through Digikey for $200 total. I'll wait a week to save $200. I've ended up buying quite a few parts from Farnell's, just outside London, because it was cheaper, even with shipping.Leave a comment:
Re: CEC Capacitors
Also, when you say primary caps, are you talking those big giant ones? I thought they were called PFC Booster Caps and I thought there was generally only one. I haven't heard of Cornell Dubilier, but I haven't heard of a lot of capacitor manufacturer names. I ran across a company called EPCOS, and that had one that looked real nice, for the PFC Booster Cap, but I'm not replacing that one. I think the one in this is a Hitachi HP3. Those EPCOS ones I was looking at, they said they were self-healing and had a really long lifetime rating of 10,000 hours @ 85c. But I'd have to buy a minimum of 240 and they're around 6$ - 7.50$ a pop!!!! I couldn't purchase that many of them, but boy, would I love to find one of them somewheres.Leave a comment:
Re: CEC Capacitors
Yeah, I figured you didn't actually need the datasheets anymore, but I've seen a lot of posts of people asking for them and when I used google to search for them, I was redirected here, so I thought hey, want not share in case someone else goes looking, you know what I mean?
I just happen to be recapping an Enermax PSU as well. I wanted to use some nicer caps that had a much longer lifetime (around 10,000 hours) but in some areas, I had to go for ones that only had 3,000 or so hours. It's because the caps that were on there where only 10mm in diameter (3,300uF and either 10v or 16v). They were sooooo close together that if you moved one of them, they'd all move. I could only find one capacitor that was 10mm in diameter at that capacitance and voltage rating. If I could have fit 12mm in diameter caps there, I could have gotten the 10,000 hour lifetime caps. That would have been nice!Leave a comment:
Re: CEC Capacitors
Thanks Spork...
The Enermax PSU was re-capped a while ago with Rubycon ZLS (And two, nice Cornell Dubilier primary caps), and it's waiting to go into a K6-2 build (for old dos games)...
Still got those CEC caps sitting in a baggie here somewhere... It would be interesting to see how they test after all these years.Leave a comment:
Re: CEC Capacitors
I know this is an extremely old thread, but I came here looking for those datasheets as well. I actually found the company that I think makes them now, JYE FWE Electronics Limited Co.
http://www.jyefwe.com/en/products.html
I've downloaded all of the datasheets from their website and have uploaded them in a .zip file, in case the site ever goes down and people need them.
The zip file contains datasheets for the following capacitors:
Code:(SMD Type) Pce-TGV Pce-TRV Pce-TSV (General Type) Pce-TUK Pce-TUM Pce-UMA Pce-UMH (Power Supply or High Frequency Type) Pce-TEB Pce-THZ Pce-TLF Pce-TPE Pce-TPG Pce-TUL Pce-TUT Pce-TUX Pce-TUZ (Screw-Mount Standard Type) Pce-TME Pce-TMH (Snap-in Type) Pce-EKM Pce-TLM Pce-TMA Pce-TMM Pce-TMP Pce-TUF Pce-TUS Pce-TUW (Special Type) Pce-THE Pce-TUH (Standard Type) Pce-TKM Pce-TNP Pce-TUA Pce-TUC Pce-TUR
Code:Lead Forming and Cut Foot.jpg Packaging.jpg Product Overview - 1.jpg Product Overview - 2.jpg Tape Standard.jpg
I hope this helps someone out who's looking for the datasheets for those pesky buggers! These datasheets that I've uploaded seem to be higher quality than the various ones I've found floating around on badcaps. This company, as far as I can tell, only sells capacitors and it only sells these capacitors, so I think this might be the new owners of those pesky Pce capacitors, not that CEC company.
Thanks!Attached FilesLeave a comment:
Re: CEC Capacitors
Very nice. So TUL are the Low Impedance ones. This will do the trick. Thank you very much.Leave a comment:
Re: CEC Capacitors
Best I could find was this. - Series Table 2002-March
http://replay.waybackmachine.org/200.../ecap_e/02.htm
The TUL Series is the only one they even claim Low Impedance for.
The rest are all GP caps.Last edited by PCBONEZ; 04-11-2011, 05:01 PM.Leave a comment:
Re: CEC Capacitors
They have a catalogue on their website, but their mains specialty is not capacitors, so they're not listed in this catalogue.
I also sent them an email and asked them for info. Let's see if they get back to me.Leave a comment:
Re: CEC Capacitors
I remember now.
Their website is a waste of time.
Why have a website when you don't even LIST any of your products?
- Let alone provide product information...
I sent them an email and told them they are stupid.
.Leave a comment:
Re: CEC Capacitors
Reliability is comparable to Capxon or Teapo.
Sometimes they last sometimes not.
I have found their site before and may have data sheets.
Will get back on that.
.Leave a comment:
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
by ctroxtellI picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
- Loading...
