Soyo SY-P4VTE board Caps
  • billse
    • Jan 2006
    • 15
    How are the caps on this board.
    3 - 470uf 16V 8mm G-LUXON
    OST
    8 - 1000uf 10V 8mm RLS
    5 - 1500uf 16V 10mm RLX
    8 - 3300uf 6.3V 10mm RLX
    All the caps are silver in colour, and seems fine, got the board along with a celeron bundle in Aug 2005.
    Gonna spend a lot of time recapping or destroying some abit AB-ZM6 boards with visible badcaps i got to take home from work.
    Regards,
    Bill
  • AK0R
    • Mar 2005
    • 204
    Re: Soyo SY-P4VTE board Caps
    How old is the board? Do you know its history? None of those caps are good, so if you value your data and components, you might want to make that board a priority. If you're just learning to solder or recap, the ZM6's should be good boards to practice on until you're proficient. Topcat, Digikey, or Mouser should all have readily-available replacement parts for this board as well as the ZM6's.
    • Rainbow
      • Aug 2005
      • 1371
      If the board does not have any stability problems, I'd leave it as is. But in case of any problems, look at the caps
      • billse
        • Jan 2006
        • 15
        AKOR, i answered your question for the abit zm6 board in the other section, and i guess i'll leave the soyo the way it is, currently it isn't being used much just sitting there until i get a proper ventilated case, backordered...
        https://www.badcaps.net/forum/showth...=9280#post9280
        Plus, reviews of Soyo and some other forums say's this board isn't very good and the sata doesn't work, Soyo support for the most part they comment is a "joke".
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
        • Noodneek
          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
          by Noodneek
          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
          08-30-2024, 12:52 PM
