Capxon issues
  • dd-wrt
    • Mar 2011
    Capxon issues
    Hey Guys / All
    I hope I am on the right path and your feedback / suggestion will benefit many over at dd-wrt as well as myself.
    The issue here is with continual radio signal dropping on a Lynksys wrt-160n v3 router. The problem seems to be mostly distributed to cfe 51 (model number). There are many who think it is software related aka a driver but the problem is spread across oem firmware and dd-wrt.
    This device comes with a 500ma power adapter but recently I swapped out my 500ma for a 1000ma poweradapter and this seemed to produce a measuriable differece for me.
    I am trying to huryy and get to the Capxon point "sorry".
    I tend to think the radio dropping intermitenly and some hourly is hardware related. The device runs on 12v dc 500ma oem.
    Now I have been reading up on capicitors and found a thread making referece to the bad cap causing the device to restart "i think it was a monitor" but that statement hit home to the radio dropping signal, which mostly comes back on in a minute.
    The device is using a (Capxon 470 uf 25v) cap for the main filter cap and then there are four outher , three electrollic and one ceramic.
    My question is do any of you think there maybe a quality control issue on this device and the cheep caps are a major suspect.
    I did have a look at the bad cap manufacture list and LOL Capxon was there.
    Maybe a cap upgrade would be a resolution for this problem. Any suggestions or feedback would most appreciated.
    here is list of other caps on the router.
    1)km 470uf 25v Capxon
    2)100uf 10v
    3)100uf 16v
    4)470 uf 10v
    a small cermaic id# (CTC -fc 090-9y038) no other marking but very small.
    Thank you for your thoughts
    cheers
    thomas
  • TheLaw
    • Jan 2011
    • 477
    Re: Capxon issues
    CapXon isn't very good but they are in just about everything these days. Hard to avoid...
    Sometimes I just think its the chips that are a bit flaky. Especially in routers where they are continually pounded with requests and get hot.
    But capacitors could be the problem. When caps go bad your machine will not function as intended, regardless of what kind of equipment.
    As I said, home/personal routers get really hot because they don't use fans. Those capacitors are most likely only rated at 85C anyway.
    It could be a lot of things, but DD-WRT is very solid, so I wouldn't think it's software/firmware as you said.
    If you want to recap it and know what you are doing, there's really no harm in doing so.
    However, usually caps will show signs of going bad. They will bulge at the top, forming a dome/pyramid. If it is extreme enough, some of the electrolyte inside will seep out. So you might want to check if any are showing symptoms first.
    Final verdict: It could be a lot of things.
    Seeing you got a new power brick, maybe the power brick is bad? Just a thought...Maybe the capacitors inside of it has gone bad and supplies unstable current. But that usually doesn't happen...
    • dd-wrt
      • Mar 2011
      Re: Capxon issues
      What type of capacitor would be a better choice for the device.
      would a low esr? version be a better performer?
      thank you
      thomas
      • TheLaw
        • Jan 2011
        • 477
        Re: Capxon issues
        thank you
        thomas
        Yes Low-ESR is used for microcontroller type boards like routers/pc motherboards etc.
        Panasonic FM, Nichicon HN, Rubycon MBZ, United Chemicon LXY.
        Panasonic FM is my favorite. Match exact spec just to be sure. (Capacitance/Voltage).
        • dd-wrt
          • Mar 2011
          Re: Capxon issues
          Thank You for the promptness...
          What would the rule of thumb be for matching if only close is available.
          Would it be better to match larger or smaller?
          Really Thanks -
          • TheLaw
            • Jan 2011
            • 477
            Re: Capxon issues
            Since you don't know the exact function of each capacitor....I wouldn't really say there is a rule of thumb. Just order off of Mouser/Digi-Key/Newark and get exact.
            Those capacitors are standard values. Nothing out of the ordinary.
            • sofTest
              • Aug 2008
              • 361
              Re: Capxon issues
              You can go up in voltage rating, without any harm, and if it fits physically. Unless you know what you are doing, don't go down on voltage, or change uF.
              Be a mensch
              • TheLaw
                • Jan 2011
                • 477
                Re: Capxon issues
                Yeah, but for simplicity's sake....
                • gretti
                  MSI Z370-A Pro, works but does not power off or reboot and USB issues
                  by gretti
                  I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                  The MSI BIOS included the ME firmware for the board. The size...
                  10-16-2025, 02:14 AM
                • SoulFreeze
                  Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                  by SoulFreeze
                  Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                  After repairing the above issue, I realized the following remaining problem,
                  Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                  The computer recognizes headphones are connected and displays a popup in windows
                  Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                  06-21-2025, 09:53 AM
                • Nagyesz
                  Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                  by Nagyesz
                  I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                  All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                  How can I extend its lifespan? Could reflow help?
                  It has ryzen 5 5500h, rtx 2050, no soldered ram.
                  Example of the artifacts:
                  03-01-2025, 11:11 AM
                • pwnjuice
                  Bitlocker issues
                  by pwnjuice
                  Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                  Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                  Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                  01-06-2025, 05:33 PM
                • Skgod
                  Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                  by Skgod
                  Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                  Black screen, freeze
                  The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                  When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                  So can anyone tell me what would be the possible cause?...
                  10-16-2024, 08:11 PM
