AcBel power supply
  • BP61001
    • Mar 2011
    AcBel power supply
    I have an Apple PowerMac dual g4 (MDD) computer and with my last power blink the Mac doesn't startup. I had the power supply checked and they said that all of the voltages were correct. The power supply is an AcBel 360 watts and my question is should I recap it even though the voltages are correct? Thanks
  • TheLaw
    • Jan 2011
    • 477
    Re: AcBel power supply
    I'd check inside before you do anything. See if you can actually see dead capacitors...The power supply should probably be able to do its voltages alright, but not under high loads, and they will be more loosely regulated. But the actual voltage regulation is done mostly by chips and the capacitors do the smoothing. So unless the chips were fried, then the voltages would probably be okay.
    But that might be entirely wrong...As I said, check inside the power supply to see if you see any bloated, domed, or leaking capacitors...And if not, write down the manufacturer, series, and value...Certain series of capacitors are so nasty they don't even show that they are busted when they really are.
    • BP61001
      • Mar 2011
      Thanks for your help. I had to push the pmu button on the motherboard. I guess when we had the power glitch it must have done something to the PMU on the board.
        03-31-2024, 02:12 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
