Dellcapacitor replacement theory?
  • eppidrummer
    • Jan 2011
    • 65
    I have begun to replace caps on about 200 bad gx270 and gx280's. Here is what I am noticing: Most of the bad caps are along the cpu and the blown ones from dell are rubycon mcz series.
    Here is my confusion, the recommended replacement is the same cap (mcz).
    Are the existing mcz a fake from dell? If not then why cant I expect the same replacement cap to do the same thing-fail?
    I have completed 8 boards and all still going strong but if replacing with the same series, strong for how long?
    Thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Dellcapacitor replacement theory?
    No. Most likely either:
    1) The failure of the Nichicons caused a cascade effect
    2) The power supplies are defective and killed the Rubycons
    • Scenic
      o.O
      • Sep 2007
      • 2640
      3) Heat
      • eppidrummer
        • Jan 2011
        • 65
        Is it worth upgrading anything in the power supplies?
        • mockingbird
          • Dec 2008
          • 5484
          There should be "Ltec" or other substandard Taiwanese caps in there.
          These PSUs are not easy to recap. You're going to have to take it apart, and desolder wires, so if you plan on doing this, you better have a good topographical sketch before you start so you can remember how to put it back together. The soldering on Dell OEM PSUs is also sloppy on the bottom, so you have to make sure not to bridge something that should not be bridged. Lastly, you're going to have to cross reference Teapo and LTEC spec sheets to find suitable replacements.
          These PSUs are difficult to recap and I have never done it for these reasons.
          • eppidrummer
            • Jan 2011
            • 65
            Thanks for the input! After that, not sure if I want to try it myself. Have done about 8 boards so far and all still running so maybe just leave the p.s alone.
            • mockingbird
              • Dec 2008
              • 5484
              Yea, leave the PSUs unless the fans are dead (These PSUs definitely need to be tended to or else they'll overheat and take the system with them).
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • the_rem
                Unknown transformer : how to find a good replacement part ?
                by the_rem
                Hello guys,
                I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                04-23-2025, 01:48 AM
              • ezenia
                PS4 controller left stick potentiometer replacement issue
                by ezenia
                Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                09-30-2023, 02:19 PM
              • boosti45
                Macbook pro logic board replacement parts quesion
                by boosti45
                i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                08-21-2024, 05:23 AM
              • r2digital
                klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                by r2digital
                I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                04-18-2024, 03:50 PM
