Using tantal caps instead of ceramics?
  • Behemot
    • 4845
    • CZ
    I have one toy to play with now - ABIT BX133-RAID. There are places for many ceramic caps in the socket but I have little problem accessing it. I found only 10uF X7R ceramic caps here in Czech republic, buying them outside is too pricey (around half US dollar per piece is little too much considering I have to buy 100+ or even 500+ of them).
    So I was thinking about using tantal caps, is it possible? When doing so I'd of course have to find polarization of the joints in socket as long as tantals are polarized unlike ceramics.
  • Toasty
    • Jul 2007
    • 4171
    Re: Using tantal caps instead of ceramics?
    You are referring to the center of the CPU socket?
    Pictures I can find on the web only show MLCC's in there, no tantalums. Tantalums are no cheaper from my experience.
    Toast
    veritas odium parit
    • Behemot
      • 4845
      • CZ
      Yeah this ones.
      I can buy great amount of old tantalums on our equivavelnt of eBay, someone has these old ones which he wants to get rid of. Do the capacitance of tantals degradate over time? If not I can buy them even they're liek a 10 years old?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        just look for junked newer boards to salvage mlcc's from.
        just for the hell of it poly mod it.
        • Behemot
          • 4845
          • CZ
          On all dead boards I have are just tiny ceramics, I want to take the hell out of the system (with wired Tualatin). Such a low-capacity ceramics are not suitable
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            esp laptop boards are full of them.you want vcore bypasses for inside the socket?i remember these had a bunch of spots for them.use these to replace the vcore caps.
            https://www.badcaps.net/store/produc...products_id=76
            getting ready to do a friends vp6.
            • Behemot
              • 4845
              • CZ
              Yeah the board has empty soldering spots for ceramics inside socket. I've already changed all electrolytes for Samxon GC's and by these I think I could help it.
              I do not have so many polymer's right now and this would be rather expensive to poly-mod such and old MoBo
              Trodas has some info about the board on his site http://trodas.wz.cz/index.php?act=ST&f=16&t=426&s=
              • Agent24
                I see dead caps
                • Oct 2007
                • 4923
                • New Zealand
                Since the tantalums are polarized and the ceramics are not, I think you will have a problem.
                -David VanHorn
                • Behemot
                  • 4845
                  • CZ
                  Yeah I'd have to discover the polarity. I think it is polarized, as I understand it that's just another filtration of input current, just directly in socket.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Exactly. And one side will be ground, so it's trivial really.
                    A working TV? How boring!
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
