Soyo lcd monitor vt19n79 help?
  • boatman355
    • Feb 2011
    • 5
    HI, new to this site , have a question? I have a SOYO lcd monitor model VT19N79 / DYLM019A that has a part that leaked on main board and i think caused it to shut down and not power up. Part has tag on top that printed SUNNY 4325101006, does anyone know what it is and where i can buy one? I am attaching a pic of part. thanks for any help
  • jetadm123
    • 2169
    Re: Soyo lcd monitor vt19n79 help?
    Suggest you go to this link and start at post #17:
    https://www.badcaps.net/forum/showth...NNY+4325101006
    • boatman355
      • Feb 2011
      • 5
      hi, while it did give me some additional info, it did not ID the part nor tell me where to buy one, any ideas? thanks
      • jetadm123
        • 2169
        Well, if it is a coil, it should be identified by LX (where X is a number). Coils don't leak as there is no fluid in them. Therefore, I'm thinking that dried substance is some type of adhesive left over from the manufacturing process. It might have become conductive, so try cleaning it off. And you probably will not be able to find a replacement.
          by momaka
          03-15-2023, 10:17 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
          by Rick_1234
          Good evening, gentlemen.
          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
          https://drive.google.com/file/d/1L6S...ew?usp=sharing
          Things I tried
          - Bought a new AC adapter thinking that was the problem but the problem...
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
