Having trouble identifying blown Cap in AMP
  • paxman
    • Feb 2011
    • 4
    Just been searching for a replacement Cap for my AMP and came accross the forum. (Nice name )
    Thought perhaps someone here may be able to help me identify the part.
    Its a rather large Cap (55x34mm) from a Stageline amplifier and the only marking on it is M0010 (other then the polarity marking). Coulour is black.
    Having searched the the usual parts/docs sites, having no luck finding the part
  • steve2
    • 121
    Re: Having trouble identifying blown Cap in AMP
    Have you tried the AMP manufacturers website? Some of them put their schematics and or parts list online. Put the make/ model on here and someone may know.
    • paxman
      • Feb 2011
      • 4
      The Amps a Stageline STA-1508 (same series as 1504/1506). I have been looking for schematics for it but not come up with anything yet.
      The CAP is located on the main power supply board. Appears to be 48v accross it. There are 6 of these Caps in total, with this one having gone bang in spectacular fashion
      • steve2
        • 121
        I can't find anything on this either. Is the amp inop right now? Stills powers on? Pull the bad one and measure the volts on the others to make sure it is still 48VDC. If it still powers on I would pull 2 of the others like it and measure the uf on them. Then go with 100 volts and I would probably replace all 6 of them. That's just me though. I'm sure others have other ideas.
        • paxman
          • Feb 2011
          • 4
          Your previous post prompted me to go back to the manufacturers website to double check for schematics and fortunately I came accross a contact email. They got back to me within a couple of hours providing the schematics which show it to be 6800uF/63V. Although they said there was no part marked M0010 on the AMP (6 of them sitting infront of me), have to say thumbs up to them for the quick response.
          Having a search for compatible parts now, will probably replace it and its neighbour initially. If there are no other faults then will replace the rest. Just incase something else has caused it to pop, as they make quite expensive fireworks
          Still find it suprising that they werent marked. First time I've ever come accross Caps with no meaningfull markings on them
          Thanks again for taking the time to help, fingers crossed i'll be annoying the neighbours again by the weekend
          • steve2
            • 121
            That's good that they answered you. I don't understand why they only put a date code on them. If I made something, I would want to have my name on it, but I would be sure it was quality before I put it out. I did an amp for a friend in a band a few months ago. It was a QSC and they had the schematic on line along with replacement parts (which were less expensive than I could find them elsewhere). Anyway, good luck with it.
            • paxman
              • Feb 2011
              • 4
              Just thought i'd report back and confirm replacing the blown cap and the adjacent cap appears to have fixed the AMP. Found suitable replacements at RS components (have one near by). Maplin and Farnell also carry them, although Maplin is more expensive and Farnel have a £20 minimum order unless you hold a credit account.
              Just need to decide wether its better to leave the AMP on, or switch it on and off every day. It drives the multiroom audio in my house, so does get regular use.
              Either way happy its working now.
              • steve2
                • 121
                Goods news is always good. Thanks for the update.
                • badnocap
                  Trouble reading this blown capacitor
                  by badnocap
                  25V 470uF? Any help would be appreciated! This was in an Adam A7X speaker. I replaced with a different uF and voltage closest to the values I thought because it is all I had in stock. It restored the speaker to working condition but it is certainly not what I needed to do as it is putting out less volume than its sister speaker which presumably no issues....
                  11-12-2025, 01:36 PM
                • silver60618
                  Lightform LFC mini PC,Blown Component - Need help identifying or Next Steps
                  by silver60618
                  Hi gang, I have 2 of these Lightform LFC mini PC's, and both suffered a blown component near the 12V power input. Im assuming its a voltage regulator,
                  But Im unable to identify the component or its marking. (The best I can make out is M48i)
                  Can anyone help me clarify what this component maybe? or what would be the next troubleshooting or logical step to try next? Schematic is unavailable
                  I removed the IC for better clarity of traces...
                  12-29-2023, 11:59 AM
                • Fr3shGy
                  Samsung U32D970 PSU blown up (Identifying Parts)
                  by Fr3shGy
                  Hi, my U32D970 PSU (BN44-00786A) has blown up. It went out with a loud bang.
                  One of the N-Channel Mosfets (OM802C) caused a short and fried the trace and its components connecting to one of the pins of the 6A01 IC.
                  I need help to identify 2 SMD resistors which lost their markings
                  highlighted in picture 3 (RM812 and RM808).
                  Maybe someone can help me identify them, has a schematic or can give me some advice. would be much appreciated.
                  6A01 IC datasheet ( https://www.fujielectric.com/company...4-245-2013.pdf )...
                  03-25-2023, 01:58 AM
                • ibo
                  MSI GS75 10SF-227 Stealth identifying Blown part
                  by ibo
                  Hi guys,
                  Hope someone can help me out here. i have this laptop and it wont Boot.
                  now i found this blown part from motherboard but i dont know what it is and what the model nr is to order a new one. i didnt found schematics or boardview for this model. I think PU33 is the same chip....
                  03-02-2023, 02:06 PM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
