Rubycon MCZ/MBZ discontinuing?
  • guyjim
    • Nov 2010
    • 10
    I am fairly new here and I posted some time ago regarding an IBM motherboard that I wanted to repair; after much general troubleshooting I believed that the problems I was encountering with the board were down to bad caps.
    I've been attempting to source Rubycon MCZ capacitors at a local level. After emailing and telephoning my countrys distributor for Rubycon capacitors I found myself with the Rubycon "2010 Capacitors Catalog" which is printed in Japanese and English.
    There is one page regarding Rubycon MCZ/MBZ capacitors, there are no sizes etc and the catalog states "Please contact our local sales office for further details, such as case size composition."
    I contacted the distributor again and they replied with the following;
    "Please see response bellow from my product manager.
    The MCZ & MBZ range is planned for end of life this year and these series won't be included in the new catalogue due out in April.
    We are recommending that the customer looks at the following series as an alternative.
    ZLH/ZLG/ZLJ or ZLK."
    I was just wondering what your thoughts on this are? I had a look at the series that they recommend as an alternative but they are not described in the same way that the MCZ/MBZ are, would they actually be suitable replacements as suggested?
    Thanks in advance.
  • Colt45ws
    • Jan 2009
    • 174
    Re: Rubycon MCZ/MBZ discontinuing?
    ZLG appears to be the closest, but not quite MBZ level even. Does not appear they have any ultra low ESR caps like MBZ/MCZ anymore.
    • guyjim
      • Nov 2010
      • 10
      Hi Colt45ws
      Thank you for that.
      I will see how much the ZLG are.
      Is there any kind of best secondary or even third place brand? How are Panasonic FC series for example?
      Thanks in advance.
      GJ.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        fc are nowhere near a replacement for mbz or mcz.
        the writing is on the wall anyway.polys are taking over.
        • guyjim
          • Nov 2010
          • 10
          Hi kc8adu,
          Thank you for the reply.
          I hear what you're saying.
          Would you be able to recommend some poly replacements for the following please? ;
          Chemicon KZJ 16v 1800uF 105 deg C x 4 (10mm)
          Chemicon KZJ 10v 1500uF 105 deg C x 3 (8mm)
          Chemicon KZG 6.3v 1500uF 85 deg C x 2 (8mm)
          Chemicon KZG 6.3v 1000uF 85 deg C x 4 (8mm)
          Thanks,
          GJ.
          • baxmax
            alternative diode to Samsung TV 55 mb
            by baxmax
            Hi, Recently my Samsung 4K QE55Q60AAUXXH just suddenly stopped working_ there is no any sign of life - no red light or anything..and think, after diagnostic, it is diode DM863c SF28e PK33 siyu or one of these four. Is there any alternative I can replace with since it is hard to find it in my country and to order outside is quite difficult. thank you...
            10-21-2024, 07:35 AM
          • Norrecito
            iPod nano G3 - alternative soldering point for the white battery wire
            by Norrecito
            A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
            The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
            This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
            09-07-2024, 03:54 AM
          • luca120
            renesas IBGT alternative
            by luca120
            some days ago my induction hob have decided to die , finally I found which component result damanged, before buy a new one to be honest I prefer to check if exist an alternative component this why isn't very cheap and here i italy isn't commecialized.
            the orginal component is: rensans mofest RJH60T4
            I checked this one FGH40N60SMD, but I don't know if could be good or not, some one could help me to find a good alternative?
            thanks to all
            Luca
            11-02-2022, 05:20 AM
          • psyco744
            Phoneboard Mobil Phone Shematics Alternative Program
            by psyco744
            Dear forum members, I wanted to share with you an alternative free program where you can find some schematics related to mobile phones and tablet. I hope it will be of use to you.
            Code:
            İphone 4
            İphone 5
            İphone 5c
            İphone 5s
            İphone 6
            İphone 6s
            İphone 6s plus
            İphone 7 (intel)
            İphone 7(qualcom)
            İphone 8 (intel)
            İphone 8 (qualcom)
            İphone 8 Plus
            İphone 8
            İphone X (baseband and qualcom)
            İphone xr
            İphone xs
            04-24-2022, 03:08 PM
          • Ado02
            ZB08P03 Alternative?
            by Ado02
            I am trying to source the ZB08P03 mosfet but can't find one in the UK. Can anyone suggest an alternative?
            09-25-2023, 08:42 AM
