capacitor failure on ship
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Catastrophic failure of a capacitor and explosion in an 11kV harmonic filter
    on board the passenger cruise vessel RMS Queen Mary 2
    https://cdn.badcaps-static.com/pdfs/...e15b01846c.pdf
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: capacitor failure on ship
    That's one hell of a bang!
    Ludicrous gibs!
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      yes everything on board is usually done in a big way
      • smason
        • 1652
        Wow, that steel door was messed up. Good thing no-one was in there.
        It was probably a Capxon
        • delaware74b
          • Apr 2009
          • 628
          I bet there was a lot of underwear that needed to be changed besides those caps
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
            12/24 volt compressor cooler box inverter capacitor failure
            This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
            Found a 47uf@63 volts double the ESR value of a new one
            The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
            The main filtering capacitor was not replaced because I did not have that was not too tall
            Where the 220uf capacitor is some type of switching power...
            08-30-2022, 05:28 PM
            DVR camera recorder switching power supply capacitor failure really
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
