Capacitor Temperature Rating
  • tjohnson4
    • Nov 2010
    I've been looking around for an hour or two and there's lots of great information here on capacitors. However, I haven't found much about temperature ratings on caps. I've been mostly looking this up because I found all of the caps on my motherboard that busted are within milimeters from the heat sink and about half a centimeter from my CPU.
    So, is it better to put caps with a higher temperature rating in close proximity to a CPU or is it not really worth the effort?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Re: Capacitor Temperature Rating
    it's not really worth the effort or extra expense. If the caps around your CPU have failed and you want something a little more robust to heat failures, look into polymer caps. What board are you working with? This can narrow down what mods could be done.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You won't find much in the way of low ESR caps rated for more than 105C anyway.
      Mann-Made Global Warming.
      - Dr Seuss
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Per Hansson
        Motor run capacitor physical size vs voltage rating & measurements?
        by Per Hansson
        (TL;DR skip the first paragraph)
        I encountered my first dead motor run capacitor at a customer this week.
        For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
        (Unless a servo motor makes more sense that is).
        But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
        The pump would run but sometimes trip the 10A breaker.
        I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
        Then it could...
        09-20-2020, 06:32 AM
      • Adenitz
        Explanation of capacitor rating
        by Adenitz
        I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
        The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
        What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
        12-26-2022, 12:36 AM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
