Need help finding replacement cap
  • nickthomas16
    • Nov 2010
    • 4
    My samsung tv wouldn't turn on so I did some digging and discovered it was most likely a bad capacitor. So I opened up the back and lo and behold one of them was bulging. So I removed it from the board, but I am extremely hesitant to buy a replacement since I have never done so before, and don't want it to be the wrong one.
    Therefore I figured I would turn to the experts here and ask for some help.
    The TV is a samsung 32" LCD, here are some pics of the capacitor I removed:
    And This one:
    So what I could ascertain from looking at it...
    Made by SamWha (I think model is XC?)
    2200 uf
    105 degrees celsius (M) which I think is max temp?
    10 Volt
    height is a little under 1" (maybe like .94)
    diameter is a little over 3/8ths of an inch.
    I went to digikey.com and tried to narrow the results down, but I still had like 12 results so I was not sure, since they had different ripple currents.
    ANY help would be greatly appreciated, like I said I don't want to do more harm.
    I will be checking this topic all day, thanks everyone.
  • Wrog
    • Oct 2009
    • 472
    Re: Need help finding replacement cap
    A couple of things: which board did this cap come from? XC is the series, which is not posted on their website (maybe a custom order?). Can size by your description would be 10mm diameter by 25mm height. Replacement would depend on where the cap(s) appear, but safe bets would be Panasonic FC or Nichicon HE (assuming you have clearance for another 5mm in height). If these are from your power supply board, and the TV is more than a couple of years old, you might want to replace the rest of the caps as well while you have it open.
    A couple of other suggestions: This thread should probably be in the TV section, and you should list the model of the TV so that it will help others. You should also read the FAQ on posting pictures! Use the "Manage Attachments" button when posting instead of using offsite linking.
    • retiredcaps
      • Apr 2010
      • 9271
      2200 uf
      10 Volt
      First, please don't post images inline as they slow down loading of pages. Use the manage attachments instead.
      This post by PlainBill might be useful ...
      https://www.badcaps.net/forum/showpo...8&postcount=11
      --- begin sig file ---
      --- end sig file ---
      • nickthomas16
        • Nov 2010
        • 4
        Thanks for the swift reply, I will most likely buy the panasonic one and see how that works out, but I figured I would answer your questions first just in case
        So its coming from the power supply board, I took some pictures of that too:
        attachment1
        Bottom right is where I removed the bad cap
        attachment2
        Just to get another angle.
        The rest of the caps look pretty good, so I think I will just replace the one broken one (even though I realize it is a better idea to replace all of them).
        EDIT:
        Really sorry I posted this after you told me not to do this! It won't happen again.
        Last edited by nickthomas16; 11-26-2010, 01:49 PM. Reason: oops on the images again
        • retiredcaps
          • Apr 2010
          • 9271
          • nickthomas16
            • Nov 2010
            • 4
            Originally posted by retiredcaps
            You have 30 minutes to edit your post and remove the inline images.
            For some reason I thought people would be nice to me and not give me ultimatums....hm.
            I did as you commanded however, I hope you are happy.
            • retiredcaps
              • Apr 2010
              • 9271
              For some reason I thought people would be nice to be and not give me ultimatums....hm.
              I was not giving you an ultimatum. I was just stating that you had 30 minutes to edit posts.
              Inline images are problematic for everyone. They slowdown loading pages. Everytime I come back to visit this thread, I have to wait for all images to get loaded and resized. On a 9 inch netbook, it makes it impossible to read the thread.
              Recently, one person loaded 12MB and had another 48MB worth of useless pictures ready to load. Imagine the time it takes to load 60MB just to read one post.
              edit: PS. If I wasn't nice, I would not have responded or helped you at all with your questions. It takes time to find these answers. None of us here get paid to answer these questions. We all volunteer our precious time and knowledge.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                lol he want trying to be rude. the forum is set up that you can only edit your post withing 30 minutes, then you cant edit anymore.
                about your tv:i recommend you replace all those caps they are all crap brands.
                • nickthomas16
                  • Nov 2010
                  • 4
                  The way it was phrased came off to me as an ultimatum, but now I understand what he was saying.
                  In regards to my TV, I really just need help finding the replacement for the cap I showed in the first post, just to get this baby up and running again
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    yes but do you want to have to open it up in a year and do this again 5 more times? and risk damaging other components inside if all the caps die?
                    have it your way: https://www.badcaps.net/store/produc...products_id=61
                    • Wrog
                      • Oct 2009
                      • 472
                      Since it's on the power supply board, definitely use lower ESR caps. Shovenose pointed out one that BCN sells here which is a perfect fit and helps support this site. The Panasonic and Nichicon I linked are larger and may not fit (please double check!). If you do end up ordering from Digikey, don't forget to use First Class shipping. It's the cheapest, and usually one of the faster ways to get it.
                      Up to you of course! The only problem is that you don't know if the others are broken by only visually inspecting them, and as Shovenose says, this could end up stressing other components and causing more damage down the road. In any case, hope it fixes your issue!
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • ezenia
                        PS4 controller left stick potentiometer replacement issue
                        by ezenia
                        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                        09-30-2023, 02:19 PM
                      • boosti45
                        Macbook pro logic board replacement parts quesion
                        by boosti45
                        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                        08-21-2024, 05:23 AM
                      • r2digital
                        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                        by r2digital
                        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                        04-18-2024, 03:50 PM
