ordering some caps..
  • indapit
    • Dec 2005
    I placed an order at mouser.com and the tech guy said these will do fine.
    Mouser
    http://www.mouser.com/index.cfm?hand..._pcodeid=64704
    Will this do fine?
  • davmax
    • Dec 2005
    • 899
    Re: ordering some caps..
    A sales team does not necessarily give good advice. The capacitors you ordered are not low ESR. No such spec there.
    They are only rated up to 10khz (should be 100Khz). Sorry not right for motherboard replacement low ESR requirements.
    See my post for Panasonic the FM series has very low ESR, high ripple ratings, long life and a good price. What more could one ask for?
    Alternately do a change order on Mouser for 647-UHE1A102MPD same can size right spec.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
    • Spacedye69
      • Nov 2005
      • 698
      • US
      647-UHE0J102MPD for 6.3v, above is 10v. $.18 a piece if ordering more than 10, $.23 a piece for 1-9.
      • davmax
        • Dec 2005
        • 899
        Yes that is correct. If INDAPIT needs to do a change order quickly he needs a stock item. The 10V is in stock the 6.3V is not. Both are 8 mm diameter and the 10V rating will do no harm and into the bargain has a lower ESR and higher ripple current rating.
        The choice is for INDAPIT.
        Thanks for being right on the money.
        Nvidia 8500GT 256Mb
        33 way card reader
        Windows XP Pro SP3
        • indapit
          • Dec 2005
          Unfortunately, I placed the order already and didn't see this forum after the fact. So, if the 10v won't hurt then I'll order that one.
          Thanks for the help.
          • indapit
            • Dec 2005
            OK, doing more research. At DIGI-KEY, they have the United Chemi-ConKY and LZX series.
            The specs again for what I'm looking for is 1000uf 6.3v 8x15mm.
            These show Low Impediance. The Panasonic are bigger 10x12.5mm. Or shall I stick to the 647-UHE1A102MPD Davmax recommended earlier.
            • AK0R
              • Mar 2005
              • 204
              At Digikey, neither Panasonic FC nor FM is available in 1000μF, 6.3V, 8mm. However, in their catalog:
              Panasonic FC: 1000μF, 10V, 8x20mm, P10224-ND, 1-9@0.53, 10-99@0.33, about 43k in stock
              Panasonic FM: 1000μF, 10V, 8x20mm, P12354-ND, 1-9@0.50, 10-99@0.365, none in stock
              • davmax
                • Dec 2005
                • 899
                There are plenty of choices. My further research revealed that Digikey has plenty of the Nichicon 1000u 6.3V 8x15 part 493-1467-ND
                http://dkc3.digikey.com/PDF/T053/0972-1006.pdf
                These have essentially the same spec as the KY series of United Chemi-con. Both are highly suitable. Just a choice of brand, price and availability.
                So over to you.
                Nvidia 8500GT 256Mb
                33 way card reader
                Windows XP Pro SP3
                • davmax
                  • Dec 2005
                  • 899
                  Apologies. The Digikey (Nichicon) link in the last post was not good.
                  This is better: http://dkc3.digikey.com/PDF/T053/1000.pdf
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                  • Spacedye69
                    • Nov 2005
                    • 698
                    • US
                    Just checked mouser.com, availability for UHE0J102MPD says on order, but when you click to view, says 2500 can ship immediately. I just ordered some a couple weeks ago and thought it said they have plenty.
                    http://www.mouser.com/index.cfm?hand...oductid=497085
                    • davmax
                      • Dec 2005
                      • 899
                      Yes Spacedye69 they do seem to be in stock at Mouser. Also at Digikey. What a choice.
                      Hope you get yours soon and have success.
                      Nvidia 8500GT 256Mb
                      33 way card reader
                      Windows XP Pro SP3
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                        EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                        by momaka
                        I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                        So, here is the...
                        06-06-2020, 04:39 PM
                      • black6host
                        Replacement caps for Samson Resolv studio monitor 65A Amp board.
                        by black6host
                        Good day!
                        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                        I'm going to replace the caps and I'll be the first...
                        02-06-2024, 08:22 PM
