hi guys i just want to ask if my board can be rapaired by recapping im new to the business but i have some soldering skills ahm i have ahn mcp6p m+ board and it just doesnt boot i have tried everything i mean everything i know tried different ram vc psu but nothing no luck the board has been wet by the rain last week and when i boot it up it smell something burned on one of the capacitor.by the way i have searched here in my town where i can buy a 16v 1500 uf but the store told me that they dont have any supply for that kind of board instead they gave me 16v 2200 uf is this good enough?? hope you all reply thanks!
hi recapping
Re: hi recapping
This is a BIOSTAR AM2+ board, which means its very recent. Bad caps are unlikely.
Did the board work fine before getting wet? You will need to remove the board from the case, then remove all the removable parts from the board and dry the board and dry all components thoroughly first. That means removing all removable heatsinks, the RAM, the CMOS battery etc.
Is your power supply dry?
Get everything dry and then see what happens. Don't even think of replacing capacitors til everything is dried out.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
