Empty Cap Spots
  • StevieC
    Talkative Loon
    • Sep 2008
    • 19
    Empty Cap Spots
    Which ones can have extra caps installed on them to make a board more stable or work for a longer time?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Empty Cap Spots
    This has been asked before here and the general consensus is not to add any capacitors and the markings are there only for saving money at the fab.
    Now power supplies OTOH, from what I understand, you can add components in designated areas, because sometimes the manufacturers skimp.
    "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
    -Leonid Brezhnev (On the Yom Kippur War)
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Empty Cap Spots
      If the position is not in parallel with other caps then it probably won't do anything at all because it is most likely there for an option [or future option, or other model option] that your board doesn't have the other parts for.
      If it is in parallel then it was probably put there in the early design phase and left [vice removed] either to allow more options at part procurement time [aka option to use more but cheaper caps] or because testing after prototypes were built showed it wasn't needed [and it costs more to redesign the PCB than to just leave the cap out].
      If you are using good quality caps there is no reason to fill the blank spots.
      About the only time it -might- help is for extreme over-clocking.
      If you aren't doing that then adding caps isn't likely to do a thing for you.
      BTW:
      Adding uF won't do much for stability in the sense I think you meant.
      - It's lowering the ESR that helps that.
      Bulk capacitance [uF] helps with 'relatively' slow transients like changing CPU load.
      Lower ESR removes more noise and noise is behind most performance/stability type problems.
      Mann-Made Global Warming.
      - Dr Seuss
      • StevieC
        Talkative Loon
        • Sep 2008
        • 19
        Re: Empty Cap Spots
        Fair enough. I'm not an _extreme_ overclocker BUT! the board is a Gigabyte GA7N400Pro2, and my CPU is an AMD Athlon XP 3200+ which clocks in at a stock 2.2 GHz. I'm considering bumping the multiplier from 11x to 12x to boost the clock-speed to 2.4 MHz and had heard that sometimes if the empty spots ARE in parallel, putting caps there can assist in reaching modestly higher clock-speeds while reducing the need to turn up V-core. Is this true? Also, one of the cap locations fouls my heat-sink. If there is an empty spot that's parallel with it which is clear of my heat-sink, could I put the replacement cap there and leave the original spot empty?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Empty Cap Spots
          If the caps are in parallel then adding one probably won't hurt and might help.
          Reports of getting higher overclock by simply replacing crap caps with good ones is pretty common. That happens because the lower ESR reduces noise giving 'cleaner' DC power. Adding a cap of the same grade will do the same thing. So will using the same number of caps with a lower ESR than the originals.
          On moving one it depends on the layout.
          - If the paralleled cap positions you are changing are all in a group then it should be no problem.
          - If they are scattered then it's hard to say because they may be scattered to keep things even on long trace runs. [Long on a motherboard can be 1.5" or less.] The tiny resistance of trace runs allows for a tiny voltage drop from one end to the other which can allow noise [tiny voltages] to exist at one end but not the other. So, if you end up with all the caps on one end of a run then you may get some noise at the other end.
          Found a photo of your board and it's an odd layout with what looks to be scattered groups of cap positions for Vcore.
          Obviously I can't tell what positions are actually in parallel in a photo so I can only give the concerns and not a solid answer.
          - Dr Seuss
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Empty Cap Spots
            use a multimeter to check continuity between points?
            sigpic
            (Insert witty quote here)
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Empty Cap Spots
              Yes, but it doesn't work with photographs.. hahahaha
              - Dr Seuss
                no-name Radeon 9600 XT recap and cooler
                by momaka
                I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                This one was actually suggested to me by ChaosLegionnaire....
                11-06-2020, 07:54 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
                Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                by momaka
                This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                Macron Power Technology Co. LTD.
                Let’s look at the PSU itself.
                The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                06-02-2021, 10:05 PM
                XFX GeForce 6800 XT AGP [PV-T42K-UDE3] – recapping and mods
                by momaka
                Aaaaand… we have more retro-PC nostalgia repairs again.
                This time it's with a XFX GeForce 6800 XT AGP video card. The XFX model number is PV-T42K-UDE3.
                As with many early XFX cards, crap caps are the main issue here. The first one I bought and recapped was back in 2017. I've been meaning to post about it for a long time, but never got around to it due to the card needing a better heatsink/cooler to test it fully with the recap (more on that later on.) In the meantime, I acquired a 2nd one of these cards not too long ago (February.) Not like this makes any difference. Both...
                07-25-2020, 02:51 PM
