I had an old Intel D865GlCL that WAS booting with leaking VRM input. So I recaped the entire thing with four 16v 1800uf MCZ's (four 16v 1500uf HD used to be there) for input. Ten 2.5v 820uf SEPEC for output (three 6.5v 820uf MCZ and seven 2.5v 680uf Chemi-con polymers were there). Then a new 6.5v 820uf MCZ for the ram. There was also a 10v 2200uf HM with a coil beside it near the south replaced by a MCZ the same size. Everything soldered in without a single scratch. Now I get three beeps at power on (64k base failure). Everything is getting the correct amount of power, and gets to normal temp by touching them. Ram and cpu are good. Would modding the vrm solid do this or changing the MBZ to MCZ in the ram do this? I don't know.
Recapping caused 64k base failure?
Re: Recapping caused 64k base failure?
Many Intel made boards [at least socket 370 thru 775] used 85C rated 4 and 5 mm caps [usually Nichicon VR] that tend to start showing up as dried out and bad after about 5 years use. Some times they even bloat though hard to see on small caps.
- Might go bad sooner in a hot case or last longer in a well cooled case.
A bad one of those could be hosing your CMOS. [So to speak.]
Can also muck-up RAM or CPU communication with the chipset.
https://www.badcaps.net/forum/showpo...0&postcount=42
.Mann-Made Global Warming.
- Dr Seuss
I wanted to replace the three wet MCZ's with polymer. But I can't just throw any 2.5 volt ones in due to very low esr and they will be fighting since they're in paralell. All the three MCZ's did was hold extra charge so the vrm input could keep up with the polys and to save a penny. So increase the uf in each input cap by 200 since each is in series. and increase the uf in the output to 1000. Good on the mosfets.Comment
EDIT: Oops, misread the previous post. Feel free to delete this one.Last edited by c_hegge; 10-10-2010, 07:40 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Have you checked for any caps in backwards?
I know you said the RAM is good, but you have a RAM error.
See if you can get to the BIOS using one stick, and then swap sticks and try again.
- No joy?
- Look for issues in +5vsb, +5v, and +3.3v [all of which can power RAM depending on the board design and it's 'state'.]
- Look at those small caps I mentioned.
- Look for problems with MOSFETs or LDOs anywhere near the RAM or chipset chips.
- Look for signs of melting or discoloration on the chipset.
If you need this up and running SOON there were two BIN type auctions on eBay for under $30 shipped at the time I posted this.
- Dr Seuss
Congrats!Mann-Made Global Warming.
- Dr Seuss
by astroboypaulI'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
The tablet when not connected to the base seems to work fine, but:- When tablet is off and connected to the base, it won't turn on.
- Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
- Charger white light turns on when connected to the base, but base battery and tablet
04-25-2025, 12:40 AM -
by npielawskiI will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...10-15-2025, 01:53 AM -
This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
This specification for the HP EliteBook 1050 G1 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Samsonite Base Boost boardview and 1050 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
This specification for the HP ProBook 640 G4 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Samsonite Base Boost boardview and 640 G4 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
- Loading...
