Bad caps on video card
  • bluechameloen
    • Nov 2005
    I've had a lot of computer problems lately, and someone online suggested perhaps bad capacitors on the motherboard might be the culprit. I opened it up and all the capacitors on the motherboard look just fine, but several of the ones on the video card are either bulging or busted right open. The problems I had been experiencing were affecting the onboard LAN, mouse, and causing my CD drive to freeze up as well as Windows XP being unable to boot at all in the end. Could all of this have been caused by bad caps on the video card? Should I still be looking for a motherboard problem, or will replacing the video card be enough?
  • Rainbow
    • Aug 2005
    • 1375
    Re: Bad caps on video card
    Check the PSU too.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      it would definately be a good idea to recap or replace the video card and see how that affects the situation. regarding the motherboard, some caps can be performing badly after some time but not showing visible signs. you can see this if you check the board using an oscilloscope while it is working.
      another place to look is inside the psu. see how the caps in there are doing. (heh Rainbow beat me to it I take too long to post)
      easy to blame problems on caps though. you may have other issues also. best to change graphics card and see how that goes. we can help you recap it properly if you like.
      can you post some pics of the card please. up to 2000x2000px is permitted.
      if you want also list the brands/series of the caps on the mobo which are 470uf and higher and we can advise if there might be a prob.
      • bluechameloen
        • Nov 2005
        Thanks. I don't have access to my computer right at the moment, but I'll have a look and come back with some more info. I don't think recapping is in the cards for me, since I have very little knowledge or experience with electronics.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          its not that difficult if they are through hole not smt caps. anyway, your choice. stick it in the for sale section if you want.
          come back with more info and we'll be pleased to assist.
