any noise through capacitor
  • pankaj
    • Aug 2010
    hello frens,
    i designed a small circuit for measuring capacitor but there is some value( ~ 280 pf) its behavior is unpredictable. in circuit only resistance and capacitor is connected so no way to occurrence of any resonance condition....
    variable capacitor connected in series with 470nf capacitor.
    please help to find out the solution...........
    • 31289
    Re: any noise through capacitor
    could be parasitic resonance, are the tracks short & straight?
    try putting ferrite rings on the cap legs.
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • tony359
      by tony359
      11-28-2023, 05:18 AM
