Seeking Datasheet for 53A3P IC -- Switching IC Used in Appliances
  • Callixus
    • Aug 2025
    • 16
    • US
    Hi!
    The subject line says it all. It's just a silly old 8 pin IC used in things like old Cuisinart coffeemakers to turn things on and shut things off. For the experience I am spending way too much time repairing one such coffeemaker, but I'm learning a lot.
    Thanks!
  • Callixus
    • Aug 2025
    • 16
    • US
    I want to add that I already searched AllDataSheets.com, even found likely leads for the datasheet, which all sent me back to AllDataSheets, etc. AllDataSheets was a red-herring: These links would pull up components with similar part numbers, but they were not even ICs or anything close. Thanks for any help!
    • R_J
      • 9581
      Post a picture of the ic, what case type? if it is used to control the unit it is likely a custom programed microprocessor ic.
      • Callixus
        • Aug 2025
        • 16
        • US
        I would, but honestly, it's just an old DIP, PTH IC chip. It's not a programmable device at all. It does some switching. The timing is apparently controlled by a couple of transistors external to it. It's pretty dumb: It just powers a relay that in turn fires up the coil that boils the water and also keeps the pot warm. It's just an old, clunky, DIP chip . . . And, it's so old that I cannot find a datasheet for it! Thanks, and I'll do it if you really want to see it . . .
        • R_J
          • 9581
          It might be an optocoupler or Precision Analog Switch (as stated by one website) The ic can be ordered if you suspect it is bad.
          I also found these specs but they may not be correct
          Part Number 53A3P
          Type Precision Analog Switch
          Supply Voltage ±5V to ±18V (Dual Supply) or 10V to 36V (Single Supply)
          On Resistance 2.5Ω max at VDD = ±15V, TA = 25°C
          Off Leakage 1nA max at VDD = ±15V, TA = 25°C
          Bandwidth 4MHz (-3dB)
          Switching Time 10ns (Typical)
          Input Signal Analog and Digital
          If YOU want to provide clear pictures of both sides of the board, I'm sure it can be confirmed what the ic does.
          • Callixus
            • Aug 2025
            • 16
            • US
            Thank you! I had taken a picture of the chip itself as you suggested, and can send a couple of the board too. But, for now, here's the chip, and, as you can see, you've already identified it. It just controls the relay that controls the heating coil once a momentary contact switch is pressed. (It also runs the LED in that switch.) Once the transistors do their thing, they send a signal shutting it off.
            Here it is . . .
            • Callixus
              • Aug 2025
              • 16
              • US
              OK, sorry for the delay. I am not master of my time right now. Here are the photos, front and back, of the board. Note that as to the availability of the chip, it is not actually available in the general sense. I was only able to order one that was apparently stripped out of something -- i.e., a used chip. Yes, it shows up as available, but follow those links and you too will probably not find it. (Although if I knew what I were doing I would also be able to immediately specify a $0.35 chip that does the same thing and that is produced today . . .) The photos:
              • R_J
                • 9581
                Ali express 53a3p 53 A3p New Original Imported Optocoupler Ic Chip 53a3p - Buy New Original Imported 53a3p optocoupler Chip 53a3p 53a3p Product on Alibaba.com
                • Callixus
                  • Aug 2025
                  • 16
                  • US
                  Thanks for that. I do have 5 used 53A3P chips in hand -- from Utasource. They came down from New Jersey. I forget what I paid but it was really cheap. And they look really good -- suspiciously good. We'll see what happens . . . Thanks!
                  • Callixus
                    • Aug 2025
                    • 16
                    • US
                    Well, I had a mini-victory troubleshooting and fixing an electrical issue with a Whirlpool oven, but the ancient Cuisinart coffeemaker still has me in fits.
                    I installed the new 53AP3 chip, checked things over, and tried to flip it on. Still nothing . . .
                    So, it's back to the drawing board.
                    I am not detecting much voltage across the full bridge rectifier -- and yes, I did solder in a resistor to supply a load. I only see 0.6V which I think would correspond to the voltage drop of one of the rectifier's diodes. But, I probably don't know what I am doing . . .
                    Thanks for all the help so far! This is a learning experiment, and the student is failing . . . (-:
                    • R_J
                      • 9581
                      Check R2 and R3, if they are ok, check if ZD1 is shorted, if it is ok, try replacing MC1 capacitor, it could be open if you don't get any DC voltage across EC1 electrolytic, I drew out the components on the trace side the best I could
                      • Callixus
                        • Aug 2025
                        • 16
                        • US
                        Really impressed! Thanks! OK, I hope to get to it soon, and I will report back! Thanks!
                        • Callixus
                          • Aug 2025
                          • 16
                          • US
                          OK, so, all measurements are in-circuit unless otherwise noted:
                          1. R2 = 97Ω [seems okay to me . . .]
                          2. R3 = 98Ω [seems okay to me . . .]
                          3. ZD1 -- Pulled for testing out-of-circuit: I set up a 27VDC power source by chaining 3 9V batteries in series. I connected this power source to the Zener diode, in series with a 4.7KΩ current limiting resistor. EUREKA! Measuring across the Zener, I get a 0.1V voltage drop, reverse-biased, and then the same 0.1V drop measuring in the forward-biased direction. [This Zener testing arrangement was something I came across while researching how to properly test a Zener diode, so here too I learned much.]
                          4. For good measure I continued: MC1 out-of-circuit measures 0.68uF -- seems okay.
                          Studying what you sent, it seems that ZD1 is essentially shorted.
                          [EARLIER HISTORY, before even joining BadCaps: (1) The ugly narrow bit of solder located between the pads for D2 & D4 (but not in contact with them) is a jumper I soldered in because that bit of trace right there was fried during hamfisted testing by me at some point; (2) even before that, the diode adjacent to the relay's coil was shorted and so I replaced it when putting in the jumper (it is just downstream of the jumper); and (3) at some point EC1 had blown (maybe my fault, maybe not . . .) and I replaced it. I think these indicators (apart from (1)) would seem to support your theory about what ZD1 has been up to . . .]
                          So now I will try to source a proper Zener diode replacement. It has no markings . . .
                          QUESTIONS:
                          1. Any directions as to how to seek the replacement Zener at the local e-surplus store? Might ZD2 be affected, so I should get more than one replacement?
                          2. Your next instruction involved testing MC1. Here I am lost. My understanding of that capacitor is that it is directly connected to the 120VAC source and proceeds in parallel with R1. So, wouldn't I tend to see apparent voltage across MC1 in any event so long as R1 is good? Just for my edification.
                          3. What is the function of MC1 (marked: CBB21 684K250V)? Is it just for smoothing/conditioning? I note that at the intersection where it connects to the 120VAC, the AC takes off in one direction through MC1 and R1 in parallel, on the one hand, but then also off to the boiling/heating coil element, on the other. Is the bulky MC1 there to smooth over the transition when the coil first lights up and initially draws away considerable current?
                          4. I am attaching a photo of my load-resistor setup for testing the output of the full bridge wave rectifier. IF ZD1 (and perhaps other, yet-to-be-identified components) were not fried, do you agree that this would have been a proper setup for measuring the output of the rectifier? I.e., would I have seen the DC output measuring across this resistor?
                          Thanks!
                          • R_J
                            • 9581
                            If the zener diode is shorted, then that is likely all that is wrong, the cap seems to check ok as well. as for the diode across the relay coil, it was likely ok as well if you checked it while in parallel with the coil.
                            Are there any markings on ZD1? if not I would guess it is around 24v
                            • Callixus
                              • Aug 2025
                              • 16
                              • US
                              I had disconnect one lead of the diode in parallel with the relay's coil, so it was indeed bad. It's possible I myself fried it when I fried the trace.
                              There are no markings on ZD1. It occurs to me that I could pull and test ZD2, which looks identical, and it may be worth doing that anyway since, as mentioned in my prior message, I have already been wondering about whether or not it might have worked in tandem with ZD1 and thus suffered the same fate.
                              Thank you very much indeed!
                              • Callixus
                                • Aug 2025
                                • 16
                                • US
                                I am still stumped.
                                My diode kit arrived. Upon a very close inspection, I did discover some very faint markings on ZD1, and they seemed to be 1W4745A. I had to assume that the "W" was a blotchy "N" or that they just used a "W" back when they made this. Anyway, that corresponded to a 16V Zener, so that's what I put in.
                                It didn't work.
                                Probing around, my dodgy jumper seemed to be leaky, so I wanted to re-do that, just in case. Also, I couldn't really be sure of the part number, and R_J had said this might well be a 24V, and if that final "5" was actually a "9," then the proper diode would be 24V and that would line up better with what the relay seems to be expecting.
                                So, I re-did the jumper and installed 1N4749A -- the 24V Zener.
                                When I use a 4.7KΩ resistor across the rectifier's output, I now get 5.6V -- an improvement. This is the reverse-voltage of ZD2. But, the coffeemaker still doesn't work.
                                I think more components may be fried.
                                Again, I have replaced the electrolytic capacitor, the diode parallel to the relay's coil, and tested the switch and also the LED embedded within the switch (i.e., not on the board images, above).
                                I am not putting water in it or loading it up with coffee, but I cannot see that there is any form of sensor whatsoever anywhere that would stop me from testing this briefly -- at least until the temperature sensor on the heating element shuts it down.
                                Any additional pointers?
                                Thanks!
                                • R_J
                                  • 9581
                                  I don't think the zener diode ZD1 is that critical, it likely is a 24v. I guessed at the voltage by looking at the relay coil voltage. to check the voltage out of the bridge circuit, just measure the voltage ACROSS EC1 electrolytic cap. you don't need the 4.7k resistor for any load.
                                  • Callixus
                                    • Aug 2025
                                    • 16
                                    • US
                                    I am getting 26V across the electrolytic capacitor, once the load resistor is excluded! Thanks for that!
                                    ZD2 had nothing to do with it. I was out to lunch about that.
                                    OK, so back to the drawing board as to the rest, because the unit doesn't work. I guess I just have to go through it really methodically.
                                    It seems we have a nominally 24VDC power supply and then also a 5.6VDC power supply. But I really want to try to understand this: What is going on with this connection of a leg of the 120VAC, essentially, through to the control chip? See your markup and route of AC source through R3 and R8, then over JMP1 to an area that is involved with IC pin 2 but then also Q1. What is going on there? if you have a moment . . . It seems to be, in part, about supplying current to and controlling the LED (the "+" and "-" marks I put on the board). But what else, and why the connection to the AC? Does it have to do with overall grounding of the IC, etc.?
                                    Thanks!
                                    • R_J
                                      • 9581
                                      ZD2 is in the base of Q1? the 2sc945, which is acting like a regulator, whose 5v output would be on the emitter. not sure about R8 and jmp1 without knowing what U2 is and how it works. (Possible zero cross switching for the ic)
                                      I marked J1 1~4 If 1 and 2 are connected to the LED 4 connects to EC1 ground, what does 3 (which connects to U2 pin7) connect to?
                                      Is the LED just a power indicator or for something else?
                                      U2 pin 8 is ground, pin 6 drives Q2 base to control the relay, pin 1 seems to be +5v, pin 2 connects to jmp1 (a/c) sense, pin3 no connection, pin 5 might drive the led? pin 4 might be some sort of timing (R11, CC3)?
                                      • Callixus
                                        • Aug 2025
                                        • 16
                                        • US
                                        Thank you for all of that. I will respond later: I suspect we may have Q2 labeled in reverse, and that pin 6 is connected to the emitter. Or maybe I just don't know how to read these . . . See attached.
                                        But, now we must pause: Q2's lead has broken in handling -- or maybe already was! So, I've ordered some transistors . . . Thanks so much!
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                          DVR camera recorder switching power supply capacitor failure really
                                          by sam_sam_sam
                                          These cheap non brand capacitors at it again
                                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                          Well at least I have the cameras back on line I to try the...
                                          01-22-2022, 06:28 PM
                                        • michel74
                                          How does this switching PS work ?
                                          by michel74
                                          Yes ! How does this switching PS works ? :-)
                                          I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
                                          Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
                                          11-02-2023, 12:35 PM
