Seeking Datasheet for 53A3P IC -- Switching IC Used in Appliances
  • Callixus
    • Aug 2025
    • 4
    • US
    Hi!
    The subject line says it all. It's just a silly old 8 pin IC used in things like old Cuisinart coffeemakers to turn things on and shut things off. For the experience I am spending way too much time repairing one such coffeemaker, but I'm learning a lot.
    Thanks!
  • Callixus
    • Aug 2025
    • 4
    • US
    I want to add that I already searched AllDataSheets.com, even found likely leads for the datasheet, which all sent me back to AllDataSheets, etc. AllDataSheets was a red-herring: These links would pull up components with similar part numbers, but they were not even ICs or anything close. Thanks for any help!
    • R_J
      • 9567
      Post a picture of the ic, what case type? if it is used to control the unit it is likely a custom programed microprocessor ic.
      • Callixus
        • Aug 2025
        • 4
        • US
        I would, but honestly, it's just an old DIP, PTH IC chip. It's not a programmable device at all. It does some switching. The timing is apparently controlled by a couple of transistors external to it. It's pretty dumb: It just powers a relay that in turn fires up the coil that boils the water and also keeps the pot warm. It's just an old, clunky, DIP chip . . . And, it's so old that I cannot find a datasheet for it! Thanks, and I'll do it if you really want to see it . . .
        • R_J
          • 9567
          It might be an optocoupler or Precision Analog Switch (as stated by one website) The ic can be ordered if you suspect it is bad.
          I also found these specs but they may not be correct
          Part Number 53A3P
          Type Precision Analog Switch
          Supply Voltage ±5V to ±18V (Dual Supply) or 10V to 36V (Single Supply)
          On Resistance 2.5Ω max at VDD = ±15V, TA = 25°C
          Off Leakage 1nA max at VDD = ±15V, TA = 25°C
          Bandwidth 4MHz (-3dB)
          Switching Time 10ns (Typical)
          Input Signal Analog and Digital
          If YOU want to provide clear pictures of both sides of the board, I'm sure it can be confirmed what the ic does.
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
            DVR camera recorder switching power supply capacitor failure really
            by sam_sam_sam
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
          • michel74
            How does this switching PS work ?
            by michel74
            Yes ! How does this switching PS works ? :-)
            I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
            Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
            11-02-2023, 12:35 PM
