TDA1517 TDA1517/N3 TDA1517/N3/S5 TDA1517P Datasheet
    GENERAL DESCRIPTION
    The TDA1517 TDA1517/N3 TDA1517/N3/S5 TDA1517P is an integrated class-B dual output amplifier in a plastic single in-line medium power package with fin (SIL9MPF), a plastic rectangular-bent single in-line medium power package with fin (RBS9MPF) or a plastic heat-dissipating dual in-line package (HDIP18). The device is primarily developed for multi-media applications.
    TDA1517 Features
    • Requires very few external components
    • High output power
    • Fixed gain
    • Good ripple rejection
    • Mute/standby switch
    • AC and DC short-circuit safe to ground and VP
    • Thermally protected
    • Reverse polarity safe
    • Capability to handle high energy on outputs (VP = 0 V)
    • No switch-on/switch-off plop
    • Electrostatic discharge protection.
    Ordering Information: TDA1517/N3 TDA1517/N3/S5 TDA1517P​
  • Kemer
    Led status indicator light transfer plastic
    by Kemer
    Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
    There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
    The plastic piece doesn't appear to be broken.
    1. What are your suggestions for resolving this issue?
    2. Is the plastic piece made of special ma...
    08-19-2025, 07:02 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • corrize
    Desoldering - soldering BGA chip close plastic mini fpc connectors ?
    by corrize
    Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
    There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
    I have :
    - hot air, and a
    ll stuff around
    - true kapton tape
    - 140 and 180 degree soldering paste
    - bismuth
    - little hot plate 250 degree max
    - the new BGA chip with probably
    05-20-2025, 01:26 AM
  • corrize
    Soldering plastic low profile FPC close camera CMOS sensor ?
    by corrize
    Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
    CMOS sensor seems resist to high temps.
    But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
    I have low melting point solder.
    I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
    07-12-2024, 02:21 PM
  • geo86
    Plastic stand offs for backlight diffuser
    by geo86
    Does anyone know where to buy plastic stand offs for backlight diffuser, mainly for Vestel TVs?
    They are extremely brittle and almost always they break into pieces.
    I looked on internet but little success.
    Thank you!...
    08-22-2022, 12:40 AM
