SAMSUNG LED UN325000 PG - vertical lines
  • mariocar
    • Mar 2014
    • 19
    • Brasil
    My television started presenting lines like shown in the pictures below. The lines move, changing places according to the images on screen, and, sometimes, they disappear completely. Would, perhaps, it be a T-Con issue?
    I appreciate the help.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: SAMSUNG LED UN325000 PG - vertical lines
    I would first try and re seat the cable between the main board and T con board or wiggle them with tv on and see if it affects picture.
    It doesn't seem a tab bonding issue at first glance to me,but watch this video to learn about tab bonding issue,just in case
    http://www.youtube.com/watch?v=purk_SyiT44
    I realize you're not having the exact same picture distortion but they vary and its a good vid on what to do with it...
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • mariocar
      • Mar 2014
      • 19
      • Brasil
      Hello, martino. Thanks for your help. I tried following the steps on the video you sent me, but, unfortunately, it didn't work.
      I'll wait and see if anyone can give me another idea, 'cause I don't think I'll manage to solve this one on my own.
      • mariocar
        • Mar 2014
        • 19
        • Brasil
        Does anyone have another idea that might help me?
        • mmartell
          • Oct 2013
          • 3189
          Possibly a main board fault. Is it the same on all inputs ?
          By the way, you are missing a letter in the model number I think. UN32x5000... what series is this ?
          • mariocar
            • Mar 2014
            • 19
            • Brasil
            Thanks, mmartell. Yes, it's the same in all inputs. I'd just like to be sure it's not a screen issue, because in Brazil it's cheaper to just buy a new TV.
            The Model Code is: UN32D5000PGXZD. The version is: KS24.
            • mmartell
              • Oct 2013
              • 3189
              I can't be definitive on it but there are some who's knowledge runs deeper. I'd wait for them to chime in for you.
                Looks like a bad LCD panel to me. You can try checking some voltages on the t-con board, if you can provide a picture of it I will try and highlight them. But having seen this before with no repair success, I suspect the actual LCD panel is bad.
                This week, must have been FOUR Samsung D series TVs with bad panels!!
                • mariocar
                  • Mar 2014
                  • 19
                  • Brasil
                  Hello, tom66!
                  I just hope it's a fixable issue. That's a picture of my T-Con board. Thanks for the attention!
                  • mariocar
                    • Mar 2014
                    • 19
                    • Brasil
                    I searched online and found a youtube video (check the link below). I decided to give it a shot. First, I disconnected a flat cable, cut a piece of electrical tape and put it in different positions in the flat cable, 'til the issue was gone. I only had to re-do the process in the other flat cable, and it was done.
                    I'd like to know what happened. Does anyone have a clue why it worked? Does this prove it was a T-Con Board issue?
                    I'm attaching a few images of the procedure and the end result. The video link also follows: https://www.youtube.com/watch?v=WNgESNOtCoY
                    Thanks for the help.
                      Hmm, very interesting - perhaps a loose connection at that point? You could confirm this theory: without the tape, try pressing down on that area of the ribbon, or pulling up slightly.
                      • mariocar
                        • Mar 2014
                        • 19
                        • Brasil
                        I tried all procedures you suggested, tom66, but the lines only appeared again. They disappeared when I put the tape back on.
                          Well, it is good news. Let us know if it holds. I can only see VCOM labels there; maybe VCOM voltage going bad or connection coming loose causes problems, but I do not know.
                          • audiofreak19
                            • Apr 2013
                            • 556
                            • usa
                            If they were moving wouldn't it be a t con issue since it's not sending the correct signal down each row. If the lines didn't move then it would be easy to say its the tab bonding.
                              I've had panel faults that move, too. It's not conclusive either way.
                              • mariocar
                                • Mar 2014
                                • 19
                                • Brasil
                                Hey, guys! I'm back with updates on my t.v. status. It was functioning perfectly up until last week, when the screen turned black and the image faded to nothing. I noticed that when I turned the T.V. on, the SAMSUNG logo doesn't appear anymore, there are green vertical lines, and the sound is still working.The LED lights are also working properly.
                                That being said, I managed to buy a new T-CON board and replace the old one with it, but nothing changed. Could the issue be with the power supply unit or the main board?
                                Thanks for the support.
                                • mariocar
                                  • Mar 2014
                                  • 19
                                  • Brasil
                                  Today, I've gotten some free time, and was able to assess my TV situation.
                                  I removed the power supply and measured the electric tension in several places - A5V, B13V, B5V etc. - , and the tension was oscillating between 0 and the expected value for that specific spot. For instance, the A5V kept reading 0 to 5, then back to 0. I noticed the maximum voltage for the LED bar wouldn't be any higher than around 90,0V. The power supply's model is BN44_00460A.
                                  Could anyone possibly help me?
                                  Thank you!
                                  • mariocar
                                    • Mar 2014
                                    • 19
                                    • Brasil
                                    I still wasn't able to solve my TV issue. I've made a video taking measurements. If anyone can help me, I'll appreciate it very much.
                                    Here's the link:
                                    https://www.youtube.com/watch?v=8rTp...ature=youtu.be
                                    • Falki
                                      Colorful LCD Vertical Lines on Samsung ue55es8090
                                      by Falki
                                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                                      Sadly it has vertical lines at the left and one line in the middle-right.
                                      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                      I have factory resetted the TV as well but also with no luck.
                                      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                      A similar issue has been posted as well but also with no actual response ...
                                      08-12-2025, 04:19 AM
                                    • Stanley1843
                                      Screen Display Vertical Multicolor Lines
                                      by Stanley1843
                                      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                      06-29-2024, 11:54 AM
                                    • pni
                                      LG 49uf695v vertical coloured lines
                                      by pni
                                      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                      11-14-2025, 03:15 AM
                                    • polaro
                                      Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                      by polaro
                                      Greetings,
                                      I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                      08-27-2022, 08:46 AM
                                      09-07-2024, 05:50 AM
