Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 04-26-2013, 10:40 AM   #1
rizzz
Default acer v193w no power need help
Hi all, i have acer v193w lcd monitor, but the problem now is no power. I have replaced all electrolytic caps except big caps 100uf 450v coz no stock. But i expect the big caps is ok. Below i attach picture of power supply board and schematics with voltage value which i have measure.
Thanks for your response.
http://www.freeimagehosting.net/9frrq
http://www.freeimagehosting.net/4egxv
http://www.freeimagehosting.net/pnyfr
http://www.freeimagehosting.net/v5qk8
rizzz is offline   Reply With Quote
Old 04-26-2013, 05:35 PM   #2
rizzz
Default Re: acer v193w no power need help
Hi all, i have acer v193w lcd monitor, but the problem now is no power. The output voltage from the power supply board can`t get real voltage it should be. The 14V rails i get only 9.3V, 5V rails only 2.6V. To confirm if the power supply or the mainboard have problem, I used 24V light bulb in the 14V output line, an ON the power, no light appear, that means power supply itself have problem. I have replaced all electrolytic caps except big caps 100uf 450v coz no stock. But i expect the big caps 100uf 450V is ok. Below i attach picture of power supply board and schematics with voltage value which i have measure.
Old 04-26-2013, 06:36 PM   #3
RJARRRPCGP
City & State: Bellows Falls, Vermont
Line Voltage: 123-127V 61.5-63.5 Hz
You got counterfeit caps!
Asus P6T Deluxe
Core i7 Extreme "Bloomfield" 965
PNY GeForce GTX 960
Windows 7 SP1
SoundBlaster ZXR
Antec High Current Pro 1200 W
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 04-26-2013, 07:20 PM   #4
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Is the IC Vref Diode a through hole IC? Take it out and measure the resistance on all 3 leg combination, you may have bad ref diode IC904 (TL431).
Old 04-27-2013, 08:12 AM   #5
rizzz
Hi, budm, yes its through hole IC with 3 pin leg. I have measure all pin with analog mmeter and results is.
black probe....................red probe....................result
1......................................2.......... ..............16K ohm
1......................................3.......... ................8K ohm
2......................................1.......... ................8K ohm
2......................................3.......... ................6K ohm
3......................................1.......... ...........5000K ohm
3......................................2.......... .............300K ohm
so if the IC904 is bad, would it damage the others component near the IC.?
Old 04-27-2013, 11:58 PM   #6
budm
budm's Avatar
If that IC904 is bad due to leakage between the Anode and Cathode, it will cause the output voltage to be low, the more that Opto isolator is turn on the less voltage will be on the outputs. I would try replacing.
Old 05-24-2013, 02:52 AM   #7
rizzz
Hi, all.....this monitor already life after i replace ic901 (tea1530at), this is culprit for this problem....tq budm for help me to solve this problem.
Old 05-24-2013, 09:50 AM   #8
budm
budm's Avatar
Thanks for the repair feedback, so the SMPS IC is bad, good to know.
