Panasonic TX-32DT35E 10 time Red led blinking.
  • Diah
    • Feb 2013
    • 6357
    Hello, i had bought from ebay the 3D HDTV Panasonic TX-L32DT35E with the folowing error
    when turn it on green LED flashing fast about 5 second, then turn to Red color Flashing 10 Time, then off awhile then back flashing 10 time..always.
    when i plug it with PC via HDMI my PC know it, when it was flashing green, also i can see the Red Light over the Digital sound out put lighting red while it flashing green.
    i dont have service manual under my hand,, the A board TNPH0933 1 A
    the power supply board PSC10348D M
    i checked both there are no visible damage or cut R or F on the power suply board..
    i red on the web there fault as sleep mode if it was using HDMI , so itried all 3 HDMI with my pc, no sucess.. any help or service manauel i would be thankfull as i read hear many good members like tom66, and others.. sorry for my bad english..
    looking forward to hear from you
    Re: Panasonic TX-32DT35E 10 time Red led blinking.
    I'm going to ask a friend for the manual, and see if he can get it. May take a day or so.
    • johnboy1313
      • Nov 2012
      • 1959
      Sorry that I can't help with the TV problem, but don't worry about your "bad english". It is very clear and easy to understand. There are members here that were born and raised in an English speaking country that can't use the languange as well as you can.
      • Diah
        • Feb 2013
        • 6357
        thanks gues,, hope to get rid of this problem.. i will put some photo on this TV. over here
        • Diah
          • Feb 2013
          • 6357
          here are photos TX-L32DT35E with 10 time Red Led Flashing
          • Diah
            • Feb 2013
            • 6357
            Tom66, and other member.. i do understand in general power supply unit on LCD give out 3 voltage... 5 , 12, 24... pn this TV PSU give 5.24 and 15.7 ..
            this messure i had when i push main SW ON, and green LED start flashing ( boboting) before it turn to RED with 10 blinking..
            my questiones,, did this type of TV the PSU differnet from other !!!!
            or may this is the fault so the IC SSC9512 shut off to protect unit as over voltage...
            i cant sperated the 12 ( 15,7 V) from PSU and the AV main board.. to check the realy out going volts,, please see photo
            • Diah
              • Feb 2013
              • 6357
              Edit:
              well i keep play round, by forcing it reset, by press - on the tv with hold nenue on remot and turn it on keep pressing power buttom, the good things i think it had half reset or the firmware damage, . now the condition, when press power on,, blink the green LED then stay stable on, voltage on PSU saty but as i wrote before the 12 should be read 15,7V. after 3 second the green LED blinking again, and stay green stable but the voltage gone.
              my questiones now,, any other trick with remot control to make hard reset on the panasonic TX DT serie...?
                Still no reply from my friend, will see soon if he gets back.
                • Diah
                  • Feb 2013
                  • 6357
                  hahaha i forget to add my result on this post, well it was just socket of the LED backlight strip no 3 right down , it was just out from it place on strip and make short contact with chassis,... any way this set sold as parts. worth more to sell one pieces include panel
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    A little late dont you think..... But thanks for updating the thread lol
                    • Diah
                      • Feb 2013
                      • 6357
                      yes dear... i just today i found i didn't done that, so it may common fault.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Its a common fault on all Leds but most brands dont issue an error code for it like Panasonic do.
                        • ItepK
                          Panasonic TX-P42G30E green light blinking, no video, no audio
                          by ItepK
                          Hey everyone!
                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                          This post describes my entire troubleshooting process of this TV.
                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                          I've taken the unit apart, and I've started to check some voltages:
                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                          12-22-2023, 05:06 AM
                        • matthewmcconaughey
                          I need help with my friend Sony GDM-FW900 24ā€ CRT
                          by matthewmcconaughey
                          Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                          I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                          1. It started with a bright and greenish picture upon starting a cold monitor.
                          2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                          05-16-2023, 03:15 PM
                        • shahnld
                          Sony kdl 65xg9505 green amber blinking
                          by shahnld
                          Good Day.
                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                          01-03-2024, 03:05 PM
                        • ikelectro
                          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
                          by ikelectro
                          Schematic : DAOP5EMB6E0 REV:E​
                          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
                          Any help or guide to proceed?...
                          03-19-2025, 08:17 PM
                        • jxrepman
                          Asus X453MA won't turn on and green led light blinking
                          by jxrepman
                          Hi there,
                          I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                          I have checked the charger and it is giving 19+ V
                          I have disconnected the battery and pressed power button for 30 seconds.
                          I tried another RAM stick.
                          Tried disconnecting the keyboard and touchpad.
                          Tried disconnecting the HDD and the wifi adapter.
                          The problem persists.
                          Hope you could help me out on this one. Thank you.
                          12-14-2024, 06:40 AM
