recapped psu 37lc2d lg tv no pic no sound
  • BadCat
    • Jun 2012
    • 3
    I have posted this same question in the wrong forum? I beleive this is the right place to ask if any one can get me started on the next step. I have replace the obvious bad caps on the psu now I get 16 blinks on the power led then steady green no pic no sound back light is lit and steady. Just want to know what to check next, or if I need to go and lay down in traffic (JUST KIDDING)! New to this and Im learning all the time Thank YOU
    Re: recapped psu 37lc2d lg tv no pic no sound
    Pictures of PSU? Check 3.4V output, common failure.
    • keats11
      • Nov 2012
      • 88
      I just acquired a 42LB1DR Tv also, no picture, no sound, backlights on. 3.4 V line reading 1.8V. Tom666-- Do you know of a board level fix/root cause for this problem? If not, I will have to buy the whole board and hope it would fix the TV. Please let em know.
        I just ended up replacing the PSU. I suspect the controller IC (8 pin chip; next to the other two 8 pin chips) is the failure, but I never got to replace that part because I blew something else up on the PSU.
        • snorlin
          • Jan 2011
          • 13
          I bought a 37LC2D from a guy on CL that had backlights, but no pic or sound. Used my ESR and found (other than the obvious bad caps) that 2 - 470u 10v and 1 - 680u 10v caps next to the connectors measured high. Replaced them and the set works. Hope that helps somebody.
            Thanks for posting back the fix. On the 37LC2D I serviced there was one bad cap (and it got really hot, the whole board was toasted under it.)
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              tom ive just picked one of these up from freecycle in bits psu removed etc yes i have one bad bulged cap and the board has got very hot underneath did you have to repalce and surface mount parts or did you just hook the psu to a bulb to test? i know its a old thread and you may not remember im also trying to find a good picture of the back of one of these sets to show me where all the connectors go i may be able to work them out but they have been removed from the mainboard too so just have a bag of wiring harness and screws etc.
              37lc2d-ec
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                http://www.3030.com.tw/Image/jv-LG-37LC2D-01.jpg
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  thanks selldor very close but not the same the set i have (will upload pics soon) has two mainboard side by side with 3 white and one grey multi strand wire connector joining them together one board has scart inputs one has hdmi/ldvs connector on cheers for trying to help have to pop out soon will check back later
                  37lc2d-ec
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    https://www.badcaps.net/forum/attach...9&d=1353449783
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      thanks selldoor top link spot on i will replace the capacitors the put the harnesses back in correct place cheers again will update when done repair tomorrow.
                      second link i get download error on pdf?
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        I just click on "open" and it works fine? I am using Opera and opens with Adobe reader
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          cheers will try firefox in a bit any way new problem i took out and measured all the caps to place a order but for now ive installed some used tested esr and uf wise caps now im back to the psu clicking constantly ive took the psu bk out of the tv and using 1k resistor 5v standby and on the relay just clicks about every 10 seconds so must be a short on the psu somewhere i leant my digital camera out so cant upload pics till tmoz.
                          PSU LGLP2637HEP
                          some one else has had the same issue ive just pmed him too see if he replies
                          i just fixed my LG 32 lcd tv, psu model lglp2637hep, i found only one bulgecap and psu relay was clicking on and off as soon power cord was applied, and no led lights,
                          have you checked all the correct voltages on you connector sockets, i had to replace two shorted mosfets.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            Thanks selldoor link works great in firefox on my laptop ive managed to find a gauranteed psu fot £19.00 delivered so took a chance on it.I had a good look at old psu under magnification various parts was heat stressed and turned dark brown also one of the psu to mainboard sockets had turned yellow with overheating so will see how the second hand psu does when i comes (my luck the screen will be cracked haha) will update when it comes.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              time for update on this well i replaced the psu set power up fine screen ok showed no signal screen which was weired since i had a aeriel in any way decide to do a full scan to see what happens it completed ok and had a great picture now the issue no sound tested all votages on ps all spot on except 3.4v on this reads 2.00volts read a few threads a few members have this issue on this pin all the other 3.4 volts are fine reading 3.4 volts. anyway checked tv speakers was turned on and they are on, i then decided to do a factory reset and redo scans etc after this the sound has been on fine for hour no issues at all i will try powering it on and off and un plugging it from the mains as thses sets dont have a power swich it just goes to standby.so i not sure if this is a intermitant fault or somehow the set remembered how the old powersupply had failed ie 3.4v fault overheating and blown caps.
                              • alan321
                                • Jan 2015
                                • 3
                                • Mexico
                                Hi there, I'm trying to fix an lg 37lc2d tv the problem that I have is that when I connect tv the green light blinks about 14 times and then it comes steady but I have no sound and video and optical output light is off, I have checked 19, 6, 3.4 and 5 volts and it seems to be ok, I can turn on the tv if I press a button on the main board that seems to be reset, the optical light turns on and about 2 seconds tv turns on, and if I disconnect and connect "3.4v on" pin from p201 tv turns on too. Another thing that I found is that 12v when I haven't pressed reset button is about 11.3v but when I press it goes to about 9v and in less a second when backlight turns on it goes to 12v
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  We do not like double posts it just wastes our time and limited resources. Suggest you edit one to say sorry double post
                                  • alan321
                                    • Jan 2015
                                    • 3
                                    • Mexico
                                    Sorry for double posting I was just looking for a quick response, can you tell me how to edit the other post?
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • Christos Tsiligiannis
                                      Marian Trace Alpha sound card repair help
                                      by Christos Tsiligiannis
                                      Hello to the forum.
                                      My name is Christos, I am new to the forum here and i am posting from Greece.
                                      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                      So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                      11-18-2024, 05:26 AM
                                      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                      This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 02:30 PM
                                      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
