CapXon capacitors quality
  • skoker
    • Jun 2012
    • 2
    • Brazil
    Several current power supply units are coming with CapXon capacitors, which have been meaning of explosions not long time ago, and I wonder how good the quality of them lately and if there is any relationship between the problems with this brand electrolytic capacitors with solid capacitors of the same, that I noticed in some power supply units manufactured by FSP.
    (Sorry for bad english, GoogleTranslate helped me)
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: CapXon capacitors quality
    Capxom are the new Fuhjyyus in my opinion. Very bad quality.
    Last edited by Evil Lurker; 06-10-2012, 10:08 PM. Reason: Spelling error... I played too much Nintendo in my early years... want to spell capxon like capcom.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      They are also used in CWT-based Antecs alongside Fuhjyyu caps.
      My True 430 1.0 purchased in October, 2003 has mostly Capxon.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Plain and simple: there's none.
        I regularly get 2-3 year old Fortron Source / FSP based PSUs (especially be-quiet (with their nonexistant airflow) and Zalman) with most of their crapxons completely blown. The non-standard (not in datasheets) 8mm secondary side ones are a total painus in the anus to find good replacements for.. no one seems to make them! And there isn't enough room for more than one or two 10mm caps in the whole bunch..
        In LCD monitors, they die even faster..
        • Rulycat
          • Apr 2010
          • 724
          • United Kingdom
          Better than Fuhjjyu, worse than Teapo, Ltec, OST etc.
          CapXon primaries will probably be ok though. I'd trust Teapo primaries more.
          • skoker
            • Jun 2012
            • 2
            • Brazil
            Thanks for the replies, but on the polymer-based capacitors (which I stupidly called as solid capacitors) manufactured by CapXon, they also have problems? A polymer-based capacitor can explode?
              Polymer CapXons will probably find some way to fail. Polymer caps have similar lifespans to electrolytics (2000-7000 hours typ); but the difference is polymer caps will simply fail with no signs, whereas electrolytics usually bulge.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                There's a reason why they're called CrapXon...
                -David VanHorn
                • dragon3x
                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                  by dragon3x
                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                  power on.
                  Here are some examples :
                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                  switching supply area).
                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                  than 6.3 V.)
                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                  I replaced capacitors with aluminum-polymer.
                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                  03-21-2025, 02:46 PM
                • slybunda
                  AA and AAA battery charger capacitors?
                  by slybunda
                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                  it has inside:
                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                  2 x 470uf 16v LZ105c branded as G.Luxon
                  not heard of these brands are they any good?
                  iv attached photos of the charger and the board inside for an idea on the type of...
                  12-24-2023, 04:41 AM
                • DXseekerMO
                  Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                  by DXseekerMO
                  Hello everyone!
                  Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                  I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                  Yes
                  0%
                  1
                  All backlight strips are the same quality
                  0%
                  1
                  No
                  0%
                  0
                  12-16-2021, 03:58 PM
                • Ady2017
                  Are there any datasheets available for Elna RJG capacitors?
                  by Ady2017
                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                  05-25-2025, 02:19 PM
                  by momaka
                  03-15-2023, 10:17 PM
