Samsung cost cutting.
  • adrianl
    • Aug 2010
    • 5
    http://www.dailytech.com/article.aspx?newsid=24065
    Real nice to see that come out, working as a tech in peoples houses and seeing many dead samsung sets the past few years I already knew it of course.
  • mockingbird
    • Dec 2008
    • 5485
    Re: Samsung cost cutting.
    Look at those bulged Samwha capacitors on that picture...
    Manufacturers might also stop using Samwha once they see that Korean capacitors are not an par with Japanese.
    • Krankshaft
      • Jan 2007
      • 2328
      I've seen Samwha caps on Samsung plasma displays all the way back to 2004.
      One of my Toshiba projection TVs from 03 has them too and they've yet to bulge.
      Then again a projection set has way more ventilation than any modern display as manufacturers pack more electronics into a smaller package and still try to use passive cooling.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        more like "(Sam)Wha just happened man?"
        samwha
        sigpic
        (Insert witty quote here)
        • c_hegge
          • Sep 2009
          • 5219
          and then maybe Sam sung a song about what happened.
          Oh, if ohmly I had the capacity to resist the capacitor jokes
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            I'd laugh but my funnybone has too high a resistance to your jokes.
            • mockingbird
              • Dec 2008
              • 5485
              Samwha don't always bulge... I've changed them in Samsung LCDs.
              • yanz
                • Nov 2004
                • 910
                it would be better if they use polymer capacitor..
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  Are you crazy?! That would mean they would have to spend a few cents more on building the TV and they would end up with a product which actually lasts much longer than the warranty period
                  lol
                  That's clearly not what they want. They WANT them to fail, so average joe goes and buys a new one, cause "fixing it is too expensive"
                  (in comparison with a new junk TV that'll die the same way)
                  It's an endless cycle.
                  - Design a product (TV) that works as advertised and doesn't leave a bad taste in the users mouth, but use borderline components (caps) which make it last a bit longer than the warranty period with normal use, but not too much longer
                  - When it fails after the warranty ran out, the user will go out to buy a new one, preferably the same brand, as it "did work as advertised for years and had a good picture", instead of fixing the old unit because, again, getting it fixed in a shop is usually unfeasible compared to the cost of a new "disposable" TV -> the cycle continues..
                  My guess is that they use the caps as the "way to make it fail", cause the time it takes for it to fail is pretty constant, considering usage patterns and all.
                  A capacitor has a limited lifetime in a specific environment. If they instead used borderline diode packs or mosfets, it could fail at any time from overheating or otherwise (even early in the warranty period, which would be bad for your reputation)
                  An electrolytic capacitor will continuously degrade over time, till it's "not good enough" anymore specs wise, causing the whole device to stop working or work erratically. Much safer bet from a manufacturers point of view.
                  Regardless of which way it's done, it's still nothing more than showing your customers the middle finger.. "go buy a new one!"
                  • lti
                    • May 2011
                    • 2557
                    Some people don't try to repair their TV because it would mean that they would miss too many TV shows. They can go to Wal-Mart and buy a new TV and not miss more than an hour of television. Also, some TV repair shops intentionally make their labor costs so high that only TVs that are worth several hundred dollars or more are "worth repairing." By their logic, the TV that I repaired by replacing one cap should have been replaced by a Wal-Mart Special LCD TV that has such shitty scaling hardware that it is impossible to read text.
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      If there is one message we would like to send to those shops, it's:
                      WHY should a friggin REPAIR SHOP encourage REPLACEMENT?????
                      • japlytic
                        • Oct 2005
                        • 2086
                        Is this issue specific to North America?
                        (Officially, this is my 1000th post!)
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          I have not checked my Samsung DLP TV for bad caps...sounds like something I should do!
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5044
                            • US
                            you have to do a bunch circuit redesigns for polys. Most Polys don't have the higher voltage/cap that lytics do. Just use decent lytics. Ever notice there is like no 16V 1500 polys? Circuts in power boards (with some exceptions) require higher voltage filtering and polys just aren't made to handle high power/cap. Also you notice ESR is hardly ever a factor in caps used in power boards.
                            now this isn't completely true. High voltage REAL polys do exist, but usually have VERY low uf. You'll see more high voltage _functional_ polys. And i'm fairly sure, they might have to use more of these in series than lytics cause of such low uf, which actually does increase the price considering how expensive they are to begin with
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                              This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 06:20 PM
