What Isolation Transformer do you guys recommend? I will be using it for light duty. I was thinking about the Tripp Lite IS1000HG.
Re: Isolation Transformer
Viz Isotap II WP-27A
Have 2. Both 25+ years old.
https://www.valuetronics.com/detail/...m#.UR2mbmfld8E
Cheaper than playing (stupid) bidding wars on eBay. A hell of a lot cheaper than $400 for the Tripp Lite.
Also, keep an eye out on eBay for the "Medical Grade", straight (non-variable) units. Sometimes high wattage and good as a whole workbench isolation unit.
TLast edited by Toasty; 02-14-2013, 09:11 PM.veritas odium parit
That Staco E1010VA is also good to have.Never stop learning
Originally posted by budm View PostThat Staco E1010VA is also good to have.
https://www.valuetronics.com/detail/...m#.UR3A3Wfld8E
Again, $100 to $400 less than eBay.
Tveritas odium parit
I know, I use the Variac to feed my Isolation transformer. Good to have both, especially the current and Volt meter in one case.Never stop learning
Cheaper than playing (stupid) bidding wars on eBay. A hell of a lot cheaper than $400 for the Tripp Lite.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....
Originally posted by Toasty View Post???
You were ready to drop nearly $400 for the Tripp-Lite unit...?
You couldn't give me a free Tripp-Lite anything.
I've seen too many of their UPSes catch fire. Well 2, but that's 2 too many.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....
An isolation transformer is one of the basics. You can't touch any piece of equipment that runs directly off the line. Well, more accurately, you CAN touch it with other test equipment but that will be an exciting and regrettable afternoon.
Some variacs, notably the expensive ones are isolated, most are not. The big money pays for a large isolation transformer and hefty autotransformer in one box. Usually the variac is needed when you are fixing amplifiers that draw high amperes for unknown reasons. this feature is sometimes useful when fixing switching supplies also, because most switching supplies will start up at reduced voltages.
In the same vein, a differential input scope is a very valuable tool for many reasons, one of which is power isolation. Differential probe modules are quite expensive unfortunately.Last edited by Longbow; 03-02-2013, 11:23 AM.Is it plugged in?
