Hp L1925 lcd monitor black screen
    Re: Hp L1925 lcd monitor black screen
    Once we get the P/N of those 8-pin MOSFET, then we can tell you where to check the voltages, any P/N for that PWM IC? Is it really OZ960 as shown in the diagram that selldoor posted?
    By the way, that blue wire, it looks like it is connected to pin 8 of the IC, PIN1 of the IC is on the top right with indentation at the corner of the IC.
    Per app notes of the IC, it should be hooked up to PIN 17 through a resistor which determine the running frequency of the circuits.
    The other end of the cable is hooked up to the ground pin of the white connector, if that is the case, the Oscillator will not be running.
    This is all based on the Diagram as posted.
      It looks like an OZ960G to me
