Required schematic sony vpcsb mbx-237
    DEAR ALL FRIENDS
    THANKS FOR YOUR SUPPORT
    I HAVE REQUIRED SCHEMATIC OF SONY VPCSB
    LAPTOP HAVING TWO BOARD MOTHER BOARD AND daughter BOARD
    MODEL IS: PCG-41216W
    WRITTEN ON BOARD:
    HD5
    V032_MP_1 0L _HDI_MB
    MBX-237 REV: 1.2
    FOR DOCKING BOARD ALSO
    V030_MP_DOCKING_DB
    REV: 1.2
    CNX-458
    pl help on this regards soon,
    Re: Required schematic sony vpcsb mbx-237
    try this
    Im Back... sort of...
      What is the problem of the laptop?
        There was capacitor short at 19v power line
        that is normal but now no power up and sn608098 having no voltage at any pin,after checking with schematic i will be back soon
          Thanks ala_borbe for your support and providing the manuals,
          thanks fery much
            IHAVE GO THROUGH SCHEMATIC AND FOUND THAT 19V AVAILABLE AT MOTHER BOARD AT PIN NO 3 OF PQ 27 BUT PIN NO 6 OF PU121 SN0608098 IS MISSING , I AM UNABLE TO find the track on motherboard pin no 6 not going any way to 19v pl help any body,
              post the voltage from PU121
                I can't help with your laptop problem, but some advice: you don't need to write everyting in capitals, unless you are trying to give us all a headache.
                -David VanHorn
                  i check the voltage and found
                  1. pin no 6 of PU121 having no voltage at all check 2.2E fuseable resistance and its ok,
                  2.+3VALW is showing short
                  *PQ16 drain also showing shorting remove PQ16 even then shorting
                  PU121 all pin pin no voltage all 0v
                  Agent24 sorry for everyting in capitals i will take care in next time thanks for responce
                    Sony VPCSB1X9E MBX-237 i need schematic
                    I need schematic model: VPCSB1X9E
                    motherboard: MBX-237
                    defect: the keyboard does not work after falling
                    thanks to all
                      Re: Sony VPCSB1X9E i need schematic
                      Here you go.
                          i have the same problem,im shorted in dcbatout as labled in schematic diagram,my problem is the motherboard that im fixing has no lable and its hard for me to trace the parts,is anyone out there can give me a boardview with lable?
                            Had one of those shorted on DCBATOUT too, ended up being a ceramic capacitor. Found it using a large 3.7v lithium battery and feeling around for anything hot.
                            A working TV? How boring!
                              thank i m join this forum i have enjoy and sharring experience
                                ok thank for your solution
                                    Re: Sony Vaio VPC-SB26FG cannot power on
                                    I need board view file for mbx-237 any one can be help... I need it to make JETAG for I/O MEC1609 to programme it
