I have an HP1740 monitor which although it is new has an intermittent display failure problem. The monitor was bought 4-5 years ago together with two other HP1740's. The problem display was given a quick test at the time of purchase then returned to its box. Total hours shown was 107.
The problem display was taken into use about six weeks ago when a display failed completely.
The problem display ran for about 26 minutes then the brightness reduced followed after some 5 secs. by a complete blackness. The display LED remained lit. After some 5 mins switching the display off and on gets the display working again but the switchoff often recurs after an uncertain amount of time.
After the obvious wiring checks I moved the display to my other computer (different video card and connecting leads). There was no difference but after a couple of days the display did not fail. The display carried on without any problem for about two weeks.
After a no-problem two weeks I had two days when it went back to the 26-30 mins then failure. This 'good fortnight bad two days' has just repeated itself.
I took the discarded display apart so know that it is not easy to try a cure put the display back together to see the effect if any. So I am hoping that someone will recognise the symptoms and point me in the right direction.
I have been unable to think what could cause this bad then good behaviour.
