Hey guys, need a little help here. I recently had my monitor(ASUS 24" vk246) go out. After a little trouble shooting and help from this website I came to find out it had a 2 second to black problem. So I went to my local radio shack and got all the capacitors and replaced them. Still nothing so I did the cffl test, first -good second -good third -good fourth -nothing. So I went deeper and found that one of the tubes had broken at the connector. On removal the already brittle tube that came in that pair had snagged and broken. After a few days my replacement cffl tubes were in and I started the rehabilitation process. After it was all said and done I plugged it in and tad-ah it worked, well kinda. It seems to be brighter at one corner of the new cffl side. and there's a line that's always different colored. And after a few seconds the whole screen gets brighter and brighter then black. Ill be adding a video so you can see what I mean. https://www.youtube.com/watch?v=YATPqZLNXqU
fixed and broken ASUS vk246
Re: fixed and broken ASUS vk246
Hey thanks for the response, by nothing I mean the fouth cffl was bad. The lcd still turned on, and the method I was refering to is this.
a) TURN POWER OFF and unplug the monitor and wait 1 minute
b) disconnect CCFL #1 and plug in spare CCFL into spot #1
c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
d) TURN POWER OFF and unplug the monitor and wait 1 minute
e) reconnect CCFL #1 and disconnect CCFL #2 and plug in spare CCFL into spot #2
f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
g) TURN POWER OFF and unplug the monitor and wait 1 minute
h) reconnect CCFL #2 and disconnect CCFL #3 and plug in spare CCFL into spot #3
i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
j) TURN POWER OFF and unplug the monitor and wait 1 minute
k) reconnect CCFL #3 and disconnect CCFL #4 and plug in spare CCFL into spot #4
l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
It arrives to me all confused.. my knowledges ara limited, as a desperate test you can try to disable the protection an run with only the old couple of lamps, disconnect the new one's side, you have to write here the marking on the bigger IC on (usually under) the psu board.
Originally posted by Grandreaper View PostSo I went to my local radio shack and got all the capacitors and replaced them.
You should replace them all again with Panasonic FR FM or FC or nichicon or
other good make caps from digikey or a well known supplier.Please upload pictures using attachment function when ask for help on the repair
Hey guys, thanks for the responses. I dont believe its the caps, for I did try to power it on with just the caps replaced. Then it worked but still had the 2 second till black problem, hence checking and changing the bulbs. I will order new caps if its really needed, but some of the caps radio shack had were panasonic.
True the brand isn't enough but as I said it was fine before the new bulbs.
Here are the caps I got.
http://www.mouser.com/ProductDetail/...0Gjvw6J33lM%3d
http://www.mouser.com/ProductDetail/...fEFlFAdpcQw%3d
http://www.mouser.com/ProductDetail/...OYLVIeEYf7E%3d
http://www.mouser.com/ProductDetail/...Di0pKS7kuMQ%3d
Also sorry I forgot to add the ic earlier. rtd2482rd
Have you checked with the seller of the lamps that they are correct for this monitor
Running voltage / wattage etcPlease upload pictures using attachment function when ask for help on the repair
