My Dell 2005fpw recently started acting up with the following symptoms.
-Occasionally goes black, buttons on the front stay green. Image will come back if you power down via the button and power back up again. This cycle will repeat about every 5 min.
-Hissing type of noise
-Kind of an ozone smell after dis-assembly.
-None of the components look visibly damaged/distorted, but I
This is my first venture into computer/monitor repair, I can follow directions very well and I have already ordered new Panasonic Capacitors for the Inverter Board from digikey. Should I recap the board first or are there other diagnostic tests I should run first?
Pictures are attached
