Newby here, Intel D865 board needs several pushes of the power button to boot
    I feel a complete novice in this present company, although I'm an experienced tinkerer in some other areas (high quality bicycles, some car stuff). I have also had some success repairing water damaged cell phones.
    I love the best dumpster finds thread already, it's right up my alley! I hate perfectly repairable stuff going to landfill, or even recycling stuff for materials, when reuse would be 1000 times better.
    The query is, I've assembled a PC based on an Intel D865PERL from 2003 with a P4 2.8GHz, and it's going great. But to boot it up it frequently takes 3 or so pushes of the power button. It just "bumps" the PS and fans momentarily on the first couple of goes. No bad caps as far as I can tell but I'm now alerted to the Nichicon HM and HN problems from that time by this forum.
    I've looked in the forum but can't see anything relevant, surely it's well known to someone on here?
    Many thanks
    Henry
    Perth
    Western Australia (winter now)
    Re: Newby here, Intel D865 board needs several pushes of the power button to boot
    Others can probably help you more. However what power supply are you using with the system currently?
    It is surprising how many motherboard problems originate from the power supply.
      +1 on the power supply issues. the psu could be a junker (cheapo units = fire hazard, can you say powmax?), or the caps could be bad.
      how about pictures of any HM/HN caps. they generally swell when they fail (not always)... unlike most crap the seals are good so they don't dry out or lead at the bung.
      last, try a different case or switch the reset and power switches (if your case has them). use the new power switch to start and see if the issue changes... I have seen finicky power switches that would short twice per press and cause such a symptom.
      sigpic
      (Insert witty quote here)
        I'd advise you to take look at the motherboard (BIOS) battery, sometimes, when a battery fails it takes a few pushes on the power button to gain some energy and let the pc boot. I actually have seen this problem on numerous occasions. Second you should check for bulging caps on the motherboard and inside the PSU. Those two problems are the most likely cause for your problem. Also try replacing the power cord just for the heck of it and see what it does.
        Guns don't solve problems. I'll take 12
          Thanks all,
          Yes it appears to be bulging/bad caps on the mobo, specifically only the 5 longer ones beside the CPU socket:
          C3C3
          C2C2
          C2C4
          C1C2
          C1C3
          Intermittent starting and hang ups, now replaced mobo with another of the same.
          Would a bad Power Supply have caused these caps to fail? One thing I notice having just started using the Intel Active Monitor is that some of the voltages seem to bounce around a bit (momentarily). Particularly the +3.3V and the CPU I/O +1.5V) readings.
            Yes, a bad PSU can kill caps. What brand and model of PSU are you using?
            No, because he's from Australia, like me. Powmax PSUs don't exist here.
              Well the voltage readings bouncing around seems to be a spurious effect arising from an interaction between "speedfan" and the "Intel Active Monitor".
              So hopefully with the replacement mobo I now have a stable system.
              Thanks for the tips guys.
                so? there are crap brands there too *cough* codegen *cough*
                sigpic
                  Those wouldn't cause the issue at the switch.
                  More likely you have other blown caps or a PSU problem.
                  Blown caps in the PSU are possible too.
                  Intel sometimes uses 85C caps for the small 4 & 5 mm caps.
                  Those start going bad from dry-out after 4 or 5 years - depends a lot on heat and run-time hours.
                  They can cause a sundry of odd problems including an unresponsive switch.
                  You are expecting sensors that cost 5 cents to be fast and accurate.
                  Could also indicate a PSU problem or bad caps. [Large or small.]
                  Mann-Made Global Warming.
                  - Dr Seuss
