Hello all and thanks in advance. I have a Philips 32pfl3403d/27. It has no power. No light. No relay click when turned on just nothing. I have tested the power from the power chord and have 120v. I have tested across the fuse and it tests 120v. I checked the connector on the power board that go to main board and to inverter board with D.C. And ac Multi meter and I get no voltage to the standby pin, 12v pin, or 24v pins. I have tested these both pressing power button and without. I see no bulging capacitors on any board.
Is it safe to say the power supply board is bad?
Is there any other way to check it?
Is there a way to check main board without having a working power supply to feed it?
I know I have lots of questions but I appreciate the help!!
Thanks!
Thanks!
