Since joining BadCaps.Net I've read plenty of threads where a device malfunctions, the owner opens it up, spots bloated/bulged caps - in most cases probably the most obvious sign of a faulty component - and automatically replaces said caps. Then after reassembling it all they are surprised/bemused/pissed that it doesn't work and the original fault is still present.
In my experience I think that caps often degrade and break down over time but whilst still serviceable a different fault develops. So a visual check leads to automatic cap replacement but no investigation of any further possible cause(s).
For example I recently replaced 8 caps on a monitor power board (https://www.badcaps.net/forum/showthread.php?t=17913) even though none of them showed any visible signs of damage, but the original fault remained. After further investigation/testing/head-scratching/cat-kicking followed by a total reflow of every device/pad I once again had a working monitor.
So maybe we should not automatically think we have the problem solved once the visibly fried caps have been replaced, but also think about the possibility of more work troubleshooting to get the device fixed.
And the cat's fine. It really is. Honest.
