We use a picofuse with short legs bent and not touching everything else but for two points of solder or a ICP Nxx fuse and solder to the old, open fuse right on the circuit board. Cheers, Wizard
You mean soldering the good, new one on top of the old, open one, to avoid messing the nearby components with the heat applied directly to the board? Never crossed my mind. Basically, it is like bridging with solder, with the protection still in place, right?
ASUS ROG Maximus IX Code
Intel Core i5-7600K 3.8GHz
16gb GSKILL TridentZ RGB DDR4-3200
1 M2 SSD + 2 WD Blue 1TB (Mirrored)
Windows 10 Pro x64
GeForce GT1050
I considered that the last time I had to do it. However I couldn't locate the proper picofuse OR the smd fuse at Digi-Key and Mouser had the exact part in stock, so I went that way.
Removing the old part isn't that hard - it just takes a hotter soldering iron. Still, this is definitely a case where sticking just about any fuse with the same rating and speed is acceptable.
PlainBill
SMT fuses are a little more tricky than snapping a new fuse into a fuse holder. It's pretty easy with a little practice.
Remove the bad fuse, clean as much of the solder off the lands as possible. Drop the fuse in place and have something handy to hold it down. I suggest using a 25 watt iron with a small tip. Put a small drop of solder on the tip, hold the fuse in place, and apply the tip of the iron to the land until the solder flows onto the end of the fuse. Let the solder cool and repeat on the other end.
As an alternative, use solder paste. Again, heat the land, not the fuse.
PlainBill
Where can I get these fuse holders, the ones I've seen online are kinda huge. thanks a lot
Old thread I know.. But I have a bad 3a 125v sm fuse (f1) on my tcon board.. All I have in this crappy town is Ratshack and they dont have this fuse.. The dork working told me to jump it with a resistor.. can this be done?
For test purposes rig any sort of 3 a fuse (glass one on a fuse holder or even a car fuse) but make sure it is secure and well insulated- last time I saw this suggested it wasnt soldered securely and fell off onto the board causing unknown damage.
