My problem is the fallowing.
My acer screen X223w worked very well, I turned it off with the front button, two hours after I turned it on with the front button and nothing happens. Now I have no led to the front and the screen stays black.
I opened the screen to study the problem (cf picture)
All fuses are OK
All capacitors are OK
On CN801
While off
1) 5.05v (VCC 5V)
2) 5.05v (VCC 5V)
3) 0V (GND)
4) 0V (GND)
5) 0.03V (on/off)
While on
1) 5.05v (VCC 5V)
2) 5.05v (VCC 5V)
3) 0V (GND)
4) 0V (GND)
5) 0,03V (on/off)
I think the problem is there, the pin on/off is always near 0V, even if I push on the ON/OFF button.
On the logic board, regulator at U106
Pin 1 reads 0 volts
Pin 2 reads 3.29 volts
Pin 3 reads 5 volts
On U501 and U502 (two n channel mosfets) there is always 17.8V
On the 16 pin IC, IC501 (OZ9938), pin2 (VDD) is correct (5V)
Pin 10 (ENAble) is always 0,05V, it's not correct
Have you any idea of the source of my problem?
All fuses are OK
On CN801
While off
1) 5.05v (VCC 5V)
2) 5.05v (VCC 5V)
3) 0V (GND)
4) 0V (GND)
5) 0.03V (on/off)
While on
1) 5.05v (VCC 5V)
2) 5.05v (VCC 5V)
3) 0V (GND)
4) 0V (GND)
5) 0,03V (on/off)
Pin 1 reads 0 volts
Pin 3 reads 5 volts
