I would like your help to fix a X1900 XT video card that doesn't work properly, in fact it never did.
A little history: I bought the card in Oct 2006, it was fine in games and the various 3DMarks but it would display artifacts in ATITool (that stress test with the furry cube from 10 years ago if anybody remembers). I never RMAed it because I probably thought that they would send it back claiming that it worked fine.
The artifacts in ATITool got worse over time and the card eventually started displaying them in games as well but I could live the occasional artifact at first, then they started being too many and too big and I changed the card in Dec 2010. I have attached a couple of screenshots of the artifacts that it displayed back then if they can help.
After I replaced the card I used it in another PC for 2D use only for a few years, but now it has been sitting in a drawer for a some time and would like to try and fix it.
I have tried it earlier and it does the following:
- 2D is fine
- if I run 3DMark06 it shows a few red dots on the black screen while the test is loading
- when the test starts the card may either a) complete it fine, b) complete it with light artifacts, c) the card resets itself and I get a driver error, d) the PC freezes and I have to reset it.
- the above happens before the card has time to heat up a lot, except when it completes the test, and it does not go above 65° anyway.
I understand that this may be tricky to troubleshoot, we are looking for some component that degraded over time and I don't really know what to check (no lytics on the board, sorry, that would be too easy). Maybe a bad component in the power section, or a bad solder joint under a RAM chip or the GPU?
Here you can see high-res pics of the front and the back of the PCB:
http://www.vgamuseum.info/images/zaa...900XT_fwhq.jpg
http://www.vgamuseum.info/images/zaa...1900XT_bhq.jpg
If you have any tips that could be helpful I would be really thankful.
Thank you
- 2D is fine
Thank you
