List of power supplies manufactured by Deer/L&C - post them here
  • op1e
    • Feb 2006
    • 1
    Re: List of power supplies manufactured by Deer/L&C - post them here
    Hey, its like a wayward EOCF reunion in here, lol. Hey Oklahoma. Thought I'd contribute, just found out my favorite case has one in it. Both my friends have these and I'm going to step up my efforts to get them buy replacement psu's.
    http://www.newegg.com/Product/Produc...82E16811105147
    The L&C logo was unfamiliar to me, now i know to avoid.
    • Oklahoma Wolf
      • Dec 2005
      • 353
      Welcome
      L&C seems to be the most common one - even those with a different name on them will often still have an LC part number.
      • japlytic
        • Oct 2005
        • 2086
        Also look for Deer-style model numbers e.g. DR-A300ATX
        • UraBahn
          Scrapheap Hound
          • Nov 2004
          • 165
          I found a 'JGE' brand 300W unit, model no. JX9810UH, that looks suspiciously like a Deer. I was building a server for my work study, when I came across this power supply. I hooked it all up, and when I put the power cord in, it emitted a loud hissing noise. When I peered inside, I found the usual classic signs of L&Cishness: cheap tiny transformers, missing components, and 'Chang' brand capacitors(?). None of the caps were buldged, but the PSU was so cheesy looking inside I wouldn't want to run anything larger than 150W on it.
          I don't have any pics of the PSU unfortunately (I no longer have access to the PSU in question), but I did try and research the 'Chang' brand of capacitors, and came to the manufacturer's website:
          Changzhou Huawei Electronics Co., Ltd.
          http://en.huaweiec.cn/Corporation/in...74&dInfoId=123
          The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
          I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
          • linuxguru
            • Apr 2005
            • 1564
            Another Zebronics, labeled LC-B300ATX with all the classic crapiness - missing caps and filters, tiny secondary caps, etc., inside. The PCB is labeled Y-B200ATX Ver:3.0. The caps are a mix of those 'Rings of Saturn' logo and Canicon. The controller IC is labeled 2003 BAZ49450408H.
            Questions:
            1) Is this L&C/Deer?
            2) What are the most common failure modes on these PSUs, apart from the primary switching transistors and bulging caps?
            3) I have 2 units that worked for about 2 years, but now fail to power up. Both have good +5Vsb. No visible signs of distress. Secondary caps substituted with better stuff, but still no go. Is the '2003' controller IC suspect?
            4) Is the TL494 a direct substitute for the '2003' controller IC?
            • Rainbow
              • Aug 2005
              • 1371
              #26
              1) Looks like that.
              2) Also output rectifiers.
              3) Check output rectifiers for shorts. The controller might be bad too - but they don't fail without a cause.
              4) "BAZ494" suggests that it might be TL494 clone. Check if the circuit matches TL494 pinout. You can compare it with ATX PSU schematic (floating somewhere around the forums).
              • linuxguru
                • Apr 2005
                • 1564
                #27
                Thanks, that was the issue on one of the units. PEC SB1040CT dual 10A Schottky-Barrier Rectifier on the +5v rail - one of the two diodes had shorted out. BTW, +5v has a (fake) rating of 30A on this unit; going by the rating on the rectifier, it shouldn't be more than 20A continuous, IMHO. There's no way around this, because of the secondary diode-inductor-capacitor topology and Kirchoff's current law - each of the diodes conducts for less than 50% of the cycle.
                The 3.3v rail has a similar 10A rectifier, and the ones on the +12v rail are 3A FR302 rectifiers. That gives us a maximum power rating of 20A x 5V + 20A x 3.3V + 6A x 12V + 2A x 5V (+5Vsb) = 100 + 66 + 72 + 10 = 248 W, and I'm being very generous on the combined rating of the +5v and +3.3v rails.
                Going by the puny transformers, inductors and capacitors, I doubt that it exceeds 150 - 200 W in reality.
                https://www.badcaps.net/forum/showthread.php?t=993
                Actually, it seems to be a custom analog IC which integrates additional stuff, including a 3.3v post-regulation circuit (not always used). I can't find an exact substitute from the info on the reverse-engineered schematic zipfile that's floating around - it's identified merely as a '2003' on that schematic.
                • iMic
                  Vintage AT Power Supplies - Selecting Capacitors
                  by iMic
                  Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                  The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                  02-19-2023, 06:45 PM
                • kotel studios
                  DEER B350ATX PSU - tips on making it safer and "better"
                  by kotel studios
                  Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                  At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                  Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                  Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                  03-04-2025, 12:09 PM
                • Mark D
                  Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                  by Mark D
                  The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                  10-29-2024, 03:15 PM
                • Deby
                  List of compatible laptop motherboards
                  by Deby
                  This is a list of compatible laptop motherboard information that I have been collecting for some time.
                  And it's still ongoing.
                  Every time I come across information that a board is compatible with another, I write it down.
                  Anyone who wants to, can continue to expand the list.
                  Packed in the rar, is an excel table that has additional information.
                  Motherboards.rar...
                  05-31-2024, 04:34 AM
                • MarkRocket
                  list of PS5 Internal Fuses
                  by MarkRocket
                  This is not a definitive list, and I do not claim if it is 100% accurate so please do your own research, based on the information from littlefuse, RS, Farnell and a few other places, using information about the markings on the fuses
                  Please feel free to distribute, amend, correct, etc...
                  01-31-2025, 07:11 AM
