Samsung PN43D450A2D No Video
  • phantom715
    • Mar 2013
    • 20
    I have had this TV for almost two years. It worked fine for a while but a month ago it was being watched and then the picture just went black. Audio worked fine, TV responded to remote signals; switched inputs, changed volume. For a while when troubleshooting it, there was an instant of RGB colored static when turning it on. Now there's nothing at all when turning it on, but the audio works fine, and it still recieves signals from the remote. I have tried to find the answer online, and most of what I've found is when the whole TV won't turn on, or related to blown capacitors. I've opened it up and looked at the components & capacitors and I don't see anything obvious. I have some electrical experience, but I'm not sure what I'm looking for. I received this as a prize, so I have no receipt or warranty, and I don't have the money to have it repaired or replaced. Any help would be greatly appreciated.
    Re: Samsung PN43D450A2D No Video
    I repaired one of these a while a go. (PS43D450 -- European model and one of its predecessors, the PS42B450.)
    On the left hand side of the TV (looking at the back as in your photos) you have the Y-buffer (green board) and Y-main (orange board.)
    Centre of the TV is the power supply board.
    Right hand side orange board is the X-main.
    The smaller remaining green board is the logic/control board and the larger one is the main board (or AV board.)
    A very common failure on this model is a failure of the X-main board, though the Y-main also fails as well.
    Please read through this guide to see if you get test patterns:
    https://www.badcaps.net/forum/showpo...61&postcount=2
    If not, you will need a digital multimeter to do the rest of the repair work.
    • phantom715
      • Mar 2013
      • 20
      Awesome; thank you! I will look at it and let you know what I find.
      • phantom715
        • Mar 2013
        • 20
        I followed the instructions you gave at: https://www.badcaps.net/forum/showpo...61&postcount=2 and I get the RGB static again when turning it on; I tried a couple of times. I do have a multimeter.
          Do you ever have a solid colour screen?
          It should look like this:
          http://www.youtube.com/watch?v=JCtF5...ature=youtu.be
          • phantom715
            • Mar 2013
            • 20
            No, nothing like that.
              OK, at this point, I would suggest you find a multimeter so you can make some basic tests.
              • phantom715
                • Mar 2013
                • 20
                I've got one.
                  I can't seem to load your pictures?
                  • phantom715
                    • Mar 2013
                    • 20
                    Sorry; Google screwed up my pictures.
                    Main:
                    Left:
                    Center:
                    Right:
                      Can't see your X-main but no worry -- I can work without that at the moment.
                      On the power supply board (middle board) you will see two points. Vs and Va. They are bare metal pads.
                      One of the stickers on the back of the plasma panel will indicate what you should see for Vs and Va, the two main voltages the plasma panel requires.
                      The Vs should be around 200~210V, and the Va 50~60V for this particular panel. Set your meter to the highest DC range to measure it (do not use the AC range.)
                      • phantom715
                        • Mar 2013
                        • 20
                        Sorry, I've been without internet for the last 36 hours. I tested the voltages. The Vs holds steady at only 11vdc, and the Va holds at 2vdc. I assume that this is my problem.
                        I'm including a larger image of that board below. Photobucket keeps rotating it. It should be rotated 90 degrees clockwise.
                        • randtek
                          • Oct 2011
                          • 280
                          • US
                          You will need to test those voltages right as the TV powers up. The way I do it is to turn the TV ON, unplug the A/C cord from the rear of the set, not the wall. Put your meter lead on the test point, then plug the A/C cord back into the rear of the TV, while watching the voltage. It will probably come up, then start going back down. Repeat for both the VS and VA voltages. Reply back with the results. Tell us the highest voltage on each reading, and if it starts to go down after initially coming up.
                          • phantom715
                            • Mar 2013
                            • 20
                            I tried again, and the Vs starts at the 205vdc that it's supposed to, and then slowly drops to the 11vdc. The Va starts at the 58vdc it's supposed to, and then drops to the 2vdc. This happens both when I plug it in, and when I turn the unit on.
                              OK, in a dark room, can you see a glow or flicker from the screen when the TV is first powered up?
                              • phantom715
                                • Mar 2013
                                • 20
                                When it is first powered up, it flashes static, and then all glow/light fades away quickly.
                                • techman365
                                  • Mar 2012
                                  • 2
                                  I have this same problem with voltages dropping. Can you tell me what is causing it.
                                    Failed Y-main or X-main board.
                                    • techman365
                                      • Mar 2012
                                      • 2
                                      • phantom715
                                        • Mar 2013
                                        • 20
                                        So what would be my next step? Is this something that I might be able to fix?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • alltvrepairs
                                          Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                                          by alltvrepairs
                                          I have confirmed that I have a mainboard problem.
                                          I have tracked no hardware issued on board so might be a software dump required.
                                          I have searched a bit but wasn't able to find anything for my screen:
                                          Here are some more details:
                                          Panel: cy-nn065hgev1h
                                          Main: BN94-14180M P08F
                                          Your help much appreciated!
                                          05-16-2025, 03:03 AM
