Hi, I have this router with an issue: I can't connect with network cable or wireless, is permanent restarting, power led and USB2 led flashing. Any ideas
Draytek Vigor 2960n
Re: Draytek Vigor 2960n
Most likely the firmware is stored at the toshia tsop chip TC58NVG0S3ETA00 (128Mb chip) and the MX25L2006E is used to keep some parameters like mac address, serial number..... unles you have acces to the tools i wouldn't bother.
Look like this device can be controlled with console commands, maybe you could connect via console and perform a firmware reset or maybe a remote firmware upgrade, check the manual.
Re: Draytek Vigor 2760n
I found on the board 4 pins for serial console ( +3,3V , Rx , Tx , Gnd).
I made a connection with laptop using hyperterminal software and a simple interface. I svae this log:
ROM VER: 1.1.4
CFG 05
Vigor2760-DrayBoot-v1.3.4
CLOCK CPU 500M RAM 250M
DRAM Size: 128 MB
NAND Flash: VID=0x98, PID=0xd1, Toshiba NAND 128MB 3.3V
Bad block table at page 65472 (ver=01)
Bad block table at page 65408 (ver=01)
WarmBoot: 0x1448008
Run DrayOS...
Boot DrayOS~~
nand_read_skip_bad 1: off 0x00d00000 read failure, try again (0)
nand_read_skip_bad 1: off 0x00d00000 read failure, try again (1)
nand_read_skip_bad 1: off 0x00d00000 read failure, try again (2)
Go~~
Modes: __STDC__ 32-bit mwDWORD==(unsigned long)
mwROUNDALLOC==4 sizeof(mwData)==24 mwDataSize==24
statistics: now collecting on a line basis
============= Memwatch Auto Self Test =============
Normal Free...DETECTED
Double Free...DETECTED
NULL Free.....DETECTED
Wild Free.....DETECTED
Underflow.....DETECTED
Overflow......DETECTED
Unfree 1......DETECTED
Unfree 2......DETECTED
ALLc range: [0x811D678C:0x82AD778B](size=26218495 bytes)
Linear malloc range: [0x833855B0:0x87EFF000](size=79141456 bytes)
!!! Maxi malloc size =79141440 (st=833855c0, end=87eff000)!!!!
ifx_system_init() in:<6>CPU revision is: 00019556 (MIPS 34Kc)
Lantiq xDSL CPE VR9
Reserving memory for CP1 @0xa7f00000, size 0x00100000
<6>Lantiq CGU driver, version 1.1.27, (c) 2001-2011 Lantiq Deutschland GmbH
<6>Lantiq ICU driver, version 3.0.1, (c) 2001-2011 Lantiq Deutschland GmbH
mips_hpt_frequency = 250000000, counter_resolution = 2
<6>IFX DMA driver, version ifxmips_dma_core.c:v1.0.17
,(c)2009 Infineon Technologies AG
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
<6>Infineon Technologies DEU driver version 2.0.0
<5>IFX DEU DES initialized (multiblock).
<5>IFX DEU AES initialized (multiblock).
<5>IFX DEU SHA1 initialized.
<5>IFX DEU MD5 initialized.
<6>gptu: misc_register on minor 255
ifx_gptu_init: line=960, done!!
<6>Lantiq SSC driver, version 2.2.6, (c) 2001-2011 Lantiq Deutschland GmbH
<6>Lantiq SPI flash driver, version 1.1.9, (c) 2001-2011 Lantiq Deutschland GmbH
<6>NAND device: Manufacturer ID: 0x98, Chip ID: 0xd1 (Toshiba NAND 128MiB 3,3V 8
-bit)
<7>Bad block table found at page 65472, version 0x01
<7>Bad block table found at page 65408, version 0x01
NAND: 128 MiB
<6>ifx_pcie_rc_class_early_fixup: fixed pcie host bridge to pci-pci bridge
<7>PCI: Setting latency timer of device 0000:00:00.0 to 64
<6>Lantiq PCIe Root Complex driver, version 1.5.3, (c) 2001-2011 Lantiq Deutschl
and GmbH
PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
<7>PCI: Setting latency timer of device 0000:01:00.0 to 64
=== pAd = 83bc9140, size = 764064 ===
<-- RTMPAllocTxRxRingMemory, Status=0
RTMPAllocAdapterBlock: BeaconTxWI = 0x83bd4da8, BeaconOffset = 0x83bd4dc0
<-- RTMPAllocAdapterBlock, Status=0
MacValue=0x53920223, CSRBaseAddress=0xBC000000
Efuse Size=0x2d [2d0-2fc]
RtmpEepromGetDefault::e2p_dafault=1
RtmpChipOpsEepromHook::e2p_type=1, inf_Type=5
efuse_probe::bUseEfuse = 1
NVM is EFUSE mode
Not Fiber WAN: 0, 0
IFX SWITCH API, Version 1.1.7.2
Switch API: PCE MicroCode loaded !!
PHY0/1 addr(0x11/0x13)
<3>GPHY FW load for A2x !!
GPHY FIRMWARE LOAD SUCCESSFULLY AT ADDR : 0x770000
etc
I don't know which software to use for make an upgrade and how to put the cpu in ''upgrade mode''
Thank you
Does the message repeat over and over? if not, it is not rebooting. There are a few messages about bad blocks, this could be the problem, maybe erasing the chip and writing the firmware again may fix it, if not you also have to replace the chip but of course you need an external programmer.
When I press reset button and turn on , the router expect firmware from Lan port
ROM VER: 1.1.4
CFG 05
ROM VER: 1.1.4
CFG 05
DRAM Size: 128 MB
WarmBoot: 0x1048008
start upgrade
Enter TFTP Server F/W Upgrade Mode
Internal phy(GE) firmware version: 0
TFTP Server IP: 192.168.1.1
Originally posted by cpt.charlie View PostDoes the message repeat over and over? if not, it is not rebooting. There are a few messages about bad blocks, this could be the problem, maybe erasing the chip and writing the firmware again may fix it, if not you also have to replace the chip but of course you need an external programmer.
Is the router acting like an TFTP server? Can you connect to it? if not you could start a local tftp server with the firmware on it, the router may try to read the file and start a programming process, btw contact with draytek support, they may be kind enought to explain how to set properly the server or at least tell the name of the file that the router is expecting.
