I'm
					New Members - please post your introductions here
	This is a sticky topic.
 Hi guys, I decided to join your nice forums, I came across here when my notebook eeprom failed and I really liked the helpfulness of the forum, I hope you can help me because I still have eeprom problems with my work computer.
 I hope to have some fun here and learn more about computer electronics and improve my electronic skills.​Comment
 I read along some weeks ago. With your helpful threads I was able to reactivate an old Lenovo L412 notebook. I used the CH341A with the variable voltage ( I think called rev. 1.7) to reflash the BIOS chip.
 Now there are still problems with the fan speed and Powerhoff left but it's useable!
 ​​​​​​Regards
 ZippoComment
 ciao a tutti,
 piacere di far parte della Vostra comunità spero di esserVi di aiuto
 un saluto a tutti
 AngeloComment
 299 / 5,000
 Hello, how are you? My name is Mario Moreno, I am from Mexico, specifically from the state of Guanajuato, a micro-soldering technician and passionate about electronics and hungry for learning, I hope to contribute a lot or a little to the forum and bring as much learning as possible, addicted to video games!!!
 ​Comment
 I am here to know if someone has had a similar experience to mine, and how to fix the problem.
 I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor and an external keyboard too.
 ​​​​​There are many many components and I don't know what to check. Maybe some people have had the same problem, and if they managed to fix It, I can do the same to fix It too.
 Thank you very much for your attention.
 Regards
 ​Comment
 Hello, I've been a certified marine mechanic for over 40 years, it's a physical demanding job and is taking a toll on my body so I thought that I would try electronic repair in my spare time, it will keep my mind active and is easier on the body.Comment
 Hi I am Chris from Germany and I am interested in computer and electronics. I hope I can learn a few things from this community especially with building up a new PC for myself. I already work in the electronics as technician so i am not totally new to the topic.Comment
			by fredyjbiplease help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
 I've already
 flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you1 Photo
			by fredyjbiplease help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
 I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
 PF0002 20v
 PQ0005
 pin 5 20v
 pin 1.2.3 19.8v
 pin 4 19.8
 resistance
 source & drain 2,4 m
 source & gate 100k
 PQ0006
 pin 1.2.3 19.8v
 pin 4 19.8v...
			by fredyjbiplease help friends x1 yoga 7th no display beep melody thank you...-
							Channel: BIOS Requests ONLY!
			by fredyjbiplease help friends clean me bios x1 yoga 7th no display melody beep, thank you-
			by fredyjbiPlease help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
 usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
 LINK to Schematic -> https://www.badcaps.net/forum/troubl...b501-schematic
- Loading...
