Greetings BadCaps, i am joining mostly for knowledge/absolutely despising the "if it doesn't work throw it away" mentality of today. in my book it is better to fix a p3 pc that needs $.05 of components than waste at least $20 to buy a crummy pc that is over-bloated and unfriendly to the end user if all you need is a word processor/calculator.
New Members - please post your introductions here
This is a sticky topic.
andy from the uk, young 54 noob electronics 🤣 just got into building pc’s last year, mine all brand new then my lads from second hand equipment which he is absolutely made up with. Then started picking up a few faulty/spares Ryzen CPU’s bent pins and all that fixed quite a few of them. Then motherboards, just getting use to working out that all CPU’s don’t work with all new ram sticks 🙄. Now that I’m moving onto removing busted components and that’s quite a learning curve especially soldering and use of heat guns. Though had a few success but need more tips and info about parts so hopefully bad caps can help. Thanks up front for any info dished out sure I’ll be reading a lot of previous posts for a while. 👍😊
Greetings! Recently got into repairing laptops and micro soldering. Tired of everyone around me throwing away perfectly good hardware, so I already helped a number of people with their problems. Very excited to have found this forum, great wealth of knowledge.Comment
Greetings all!
I started teaching myself electronic repair about 2 years ago. While learning the basics I took a detour into ham radio for a while. Ham radio offers many opportunities for building your own gear and that meshed well with my love of creating things. Well, I'm back on the road for learning electronic repair and found my way here from a youtube video about electronic components and repair.
I hope to learn enough to be able to contribute here in the future.
Kind Regards,
FleetComment
Hi, I just want to say thank you for the old site of bad caps. I got some information on it about repairing, and this time I am looking forward to this new site. I have been using a soldering iron since 2015; thank you, admin.Comment
Hello Everyone,
Aerospace engineer here trying to learn a little about electronics as it pertains to repairing and maintaining my vintage stereo system.
Thanks in advance for your cordial and helpful responses, I'll try to do the same.
JimComment
Hi
I am laptop repair man level 1
initail level, as I seen badcaps as for donation in terms of datasheet brd or related electronic data we will try what we haveComment
Halo everyone, my name is Trevor and am very delighted to be new here and hopping to learn alot from this community of etra-ordinary ladies and gentlemen.Comment
Hello Guys!
I am an both an electronics enthusiast and currently working in the automotive hardware design field. Thank you!Comment
Hi There,
I'm Falk from Bremen, Germany.
I came here for the thread in the LG 27GL63 Monitor. But I guess this forum will be helpful for my DIY repairs at home.
Im a maintenance electrician, so I maybe I'm able provide helpful information as well.Comment
by fredyjbiplease help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
I've already
flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you1 Photo -
by fredyjbiplease help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
PF0002 20v
PQ0005
pin 5 20v
pin 1.2.3 19.8v
pin 4 19.8
resistance
source & drain 2,4 m
source & gate 100k
PQ0006
pin 1.2.3 19.8v
pin 4 19.8v... -
by fredyjbiplease help friends x1 yoga 7th no display beep melody thank you...
Channel: BIOS Requests ONLY!
by fredyjbiplease help friends clean me bios x1 yoga 7th no display melody beep, thank you
by fredyjbiPlease help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
LINK to Schematic -> https://www.badcaps.net/forum/troubl...b501-schematic - Loading...
