New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Re: New Members - please post your introductions here
Hi My name is Gustav, and I'm from Denmark. I'm a rather old (just turned 50) newbie, when it comes to repairing circuit boards. I have had my share of phonerepairs (display, camera and battery replacement), and a couple of laptop repairs as well, and now I'm looking into some more challenging projects - projects I'm hoping you guys can give me pointers on here and there :-)
hi, Im from wales UK and have been repairing gpu's, consoles, many things for many years, Im hoping for insight into some harder jobs ive come accross and this place seems like the right place to be!
I hail from the Volunteer State. Having just joined, I'll be searching the forums in hopes of
resurrecting our Sony kdl-55hx800. Symptoms, 3 blinking red lights on power up after lightning strike.
Thanks,
Bubba
I'm a senior coder (more than 30 years), but a noob regarding eeprom programming.
Actually, I received recently a lenovo thinkpad x260 where the UEFI is locked with a supervisor password.
I see here an occasion to learn something new, and while googling for how to deal with that, I found this forum with lots of interesting information.
I'm about to get a second hand TL866II programmer, and I hope I'll find all information on how to dump and flash the chip in this forum.
Hello. I bought some office furniture and supplies from a liquidator and it came with several HP laptops. They all work but they all have passwords on the BIOS. I'm trying to figure out how to remove the passwords without buying new motherboards.
Hello everyone!
I've been playing around with electronics since my childhood in the 1970's, mostly diagnosing and replacing parts. Recently, I found Mr. Carlson's Lab on YouTube. In June, I bought my first restore/rescue radio, a 1935/36 GE A-63 tombstone. I haven't done anything with it yet. I've been slowly accumulating tools to recap and align the radio.
I bought a Heathkit IP-5220 isolated variable AC supply for safety. I still need to build a dim bulb tester. Meanwhile, I carefully watch the amp meter on the power supply. If it were to jump very quickly, I'd shut it off.
I also just bought an EICO 324 signal generator that also needs recapped. I just bought all the components to build xraytonyb's "capacitor foil sniffer". I'd like to build Mr. Carlson's version but I hesitate to spend the money to set up for making my own PCB's, when I'll only use it to make 2 or 3 boards. My laser printer's cartridge expires really quickly and the prints get black. I may build a UV exposure unit if I can find an old flat bed scanner. That would eliminate the toner issue. I may also try printing the PCB on my inkjet printer and going to Staples to use their copy machines. I just need to check to see if they'll allow me to use my own transfer paper.
I also have bought a near mint VIZ 98C Voltohmyst. So I'm nearly ready to start on my radio. It appears it's in such good condition, I may only restore it electronically. I may keep the cabinet as is as a survivor radio rather than a restore. I just need to find four original knobs. I'll probably pay more for the knobs than the $30 I paid for the radio!
I'm glad I found this website!
Steven
Middletown, PA
So that's a little bit about VTVM Already got a mild shock
please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
I've already
flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
please help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
Please help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
