New Members - please post your introductions here
This is a sticky topic.
  • patatapa
    • Sep 2021
    • 3
    • China
    #27321
    Re: New Members - please post your introductions here
    Hello to all. I am Denis, from Albania, living in China. I own a small business in both countries, and recently took on repairing electronics as a hobby due to an "accident" with my daughter's graphic card..well i basically poked around the gpu with a paper clip because...that's what fathers do .
    The story goes something like this. I decided to build a computer for my daughter. Build it i did, and it was gorgeous, nothing too fancy a budget Phanteks P360 because of the RGB and airflow, a Phanteks PSU, a second hand MB and Ryzen5 2600 16GB of ram overkill, GSkill Trident because again..the RGB, and a Sapphire R9 270x 4gb. A modest but good looking computer. After a few days running Windoze 10 i decided to upgrade to Windoze 11, little did i know that my graphics card didn't support UEFI and Microsoft had decided it was necessary to run that disgusting system. What is a father to do? Decided to flash a new bios that supports UEFI found one on TechPower and flashed it. The screen went black, panic in the room disappointed faces around a sinking feeling all around me, what can one say. I searched and found some people that teach you to repair a bad bios by shorting the pins and without giving any context safety tips and explanation. So like a desperate person i fell for it as any desperate person falls for miracle cures and fast money schemes, and with a paper clip shorted it a couple of hundred times. Suddenly the computer violently shut down, everything went dark and nothing would power on anymore. I went from disappointment to horror and shock, in a heart beat. after a long sleepI bought another GPU, and promised my self i would fix the one i broke. So i learned what i could, bought soldering equipment multimeter flux and soldering wire, downloaded datasheets for every chip opened the card and tested it for days and days. Found out i had a 12v short to ground, searched around the mosfets finally found one with a short on GH gate. Bought another mosfet, and as i was trying to remove the old one, a electrolytic capacitor blew up and hit me right in between the eyes. Bought another capacitor, removed the mosfet and to my surprise and delight the short disappeared. Went on to remove the remains of the capacitor that blew up and broke it's pins with the remaining ones stuck in the holes. Went for the needle hot air method and finally managed it. However i found out the capacitors i bought though the correct values where slightly taller, desoldered it bought new one soldered it back and lo and behold the card was fixed...or so i thought. Sunday morning i decided i would try the card out, plugged it in with high expectations that where turned into disappointment the moment i powered the computer on... it wouldn't work. There was no voltage anywhere. Checked power mosfets all the power rails and found out the 5v coil was getting 1v only, while three of the power mosfets where giving short at the source. Little did i know that they are supposed to as they are low side mosfets whose source goes to ground, i learned about it too late i had already removed and tested each of them, and with them a couple of cermaic capacitors had flown away into the unknown a transistor had lost one of it's legs and another one had lost it's will to live. And so here the story ends, but not the "adventure" or nightmare depending on mine or the wife's point of view. What i do know for sure though, is that it's money well spent even if i don't fix it, i learned a lot of things about which i had no knowledge of, or interest for that matter, met a few nice people along the way online, found this forum, and overall the experience has been worthwhile and i hope to make it even better here.
    • ziko07
      • Jun 2021
      • 102
      • Somewhere
      #27322
      Hi, happy to join this forum
      Tnx
      • Tristan11
        • Sep 2021
        • philipines
        #27323
        Hello im tristan new member
        • john75
          • Sep 2021
          • Sauzé-Vaussais
          #27324
          Hello, French to study RT809H programmer. Thank you.
          • Puskas
            • Sep 2021
            • Hungary
            #27325
            Hello! I'm Puskás from Hungary.
            • sdv65
              • Sep 2021
              • russia
              #27326
              Good day to the forum participants!
              I'm from Russia. more than 30 years I'm repair audio-video-CD.
              Sometimes I'm need some materials for repair vintage.
              Dmitriy
              • memyself
                • Sep 2021
                • italy
                #27327
                hello, i'm luigi from italy.
                nice to meet you.
                i love games and i like to try to repair everything fault.
                i have no technician experiences, but i use the net to find helps.
                i found this forum googling, because at the moment i would like to regenerate my canon mg5650. problem was blank paper, but i think i have locked the service mode.....
                • dwd
                  • Sep 2021
                  I understand the need to do this. Seems the good ole' days of easy access chatrooms and forums are gone. I even remember the BBS days!
                  • tech9pc
                    • Sep 2021
                    • 50
                    Hi from Canada. Got to reading a lot of interesting stuff in these forums so joined.
                    • willyInfoser
                      • Mar 2019
                      • Argentina
                      #27330
                      Hi !
                      I'm Walter from argentina. I run a computer service where we repair laptops, mobiles, and desktops.
                      I find very useful to search and share the problems we have every day in ours workshops. So Im grateful to be part of this forum
                      Have a nice repair !
                      • ghostridertech1968
                        • Sep 2021
                        • 6
                        well I'm completely new to all this but i thought I'd give it a whirl. I'm an electrical engineer for a medical device company. Im not big on words so maybe this might work out for everyone since im not long winded
                          • Sep 2021
                          • 6
                          Since I'm new to all this here's the first stupid question. Where do you post what you need help with ? lol maybe I'm off to a very bad start but I'll put my question here. I need help in finding a diode on a Ysus board for a LG 60PV250-UB. The diode is shorted and I can't find it it's D248 on the board and the markings on the diode is 8815. can anyone point me to where this question needs to go or where I can purchase this diode please and thank you
                          • Dr. Strangelove
                            • Sep 2021
                            Hi and thanks for the add. I've been gifted a couple of larger televisions lately (64"plasma and 46" Led) because they are "broken" and she just buys new ones.
                            I fixed one for 11 cents and the other for about $10 because there isn't anywhere local to but capacitors and those types of electronic parts since all of the Radio Shack stores (at least in my area) closed years ago.
                            Joining to add to my knowledge.
                            • Hofnar
                              • Sep 2021
                              • Finland
                              #27334
                              HI from Finland
                                • 22114
                                Post in the tv repair forum
                                Troubleshooting TVs and Video Sources
                                https://www.badcaps.net/forum/forumdisplay.php?f=31
                                • bardi
                                  • Sep 2021
                                  • 6
                                  • canada
                                  #27336
                                  Hi There,
                                  This is Bardi, 21.
                                  I hope you can help to fix my Lenovo L380 BIOS issue.
                                  Thx
                                  • androiidd
                                    • ukraine
                                    #27337
                                    am the founder and engineer of a small company called Formus Service for the repair of electronics in Ukraine (Lviv). I'm very happy to have you. opportunity to communicate here with you!
                                    • androiidd
                                      • ukraine
                                      #27338
                                      Hello everyone! My name is Andrew I am the founder and engineer of a small company called Formus for the repair of electronics in Ukraine (Lviv). I'm very happy to have you. opportunity to communicate here with you!
                                      • elitebooker
                                        • Sep 2021
                                        • 9
                                        • Bosna i Hercegovina
                                        #27339
                                        Im new?
                                        • Hasman Ocha
                                          • Sep 2021
                                          • indonesia
                                          #27340
                                          Selamat Pagi...
                                          Terima Kasih sudah diizinkan untuk bergabubng dalam forum ini
                                          salam kenal untuk semua dari Indonesia..
                                          Terima Kasih
