Samsung UE40KU6172U blanking problem!!??
    • 12206
    • U.S.
    Re: Samsung UE40KU6172U blanking problem!!??
    thanks for explanation, I guess I didn't grasp that you was trying it without everything connected, glad it's working.
    • vinceroger69
      • Mar 2012
      • 6714
      Originally posted by lotas
      For this KU series - if the panel is not connected or the panel is not working, it will reboot, try turning off only the backlight and check if it will reboot.
      Thanks for this information lotas like they say we never stop learning new things,
      • Kingfreddie
        LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
        by Kingfreddie
        Ok.. this is the story:
        Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
        This is kinda how it looked, just that mine were at the bottom of the screen:
        09-11-2021, 01:57 AM
        09-07-2024, 05:50 AM
      • howardc64
        Samsung UN55JU650DF network/streaming problem
        by howardc64
        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
        07-09-2025, 12:44 PM
        09-06-2024, 11:40 PM
