When plugged in, the power LED blinks red continuously. Temp and Lamp lights are not lit. Nothing happens when power button is pushed. When lamp door is removed, power light is off so safety switch is ok. I find no diagnostic that has blinking red power light but no temp or lamp light lit or blinking.
BenQ HT2150ST: No power up
Re: BenQ HT2150ST: No power up
you need to tear it down... the main boards sitting on 10 pins plug .check and clean the pins first if they are became black color.... meanwhile check all 4 fans .. specialyy the one at power boards which below to lamp hose sectionLast edited by Diah; 11-14-2022, 11:55 AM.
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by ronaldo17When I press the power button, nothing happens. All I can see is the power button blinking and never stopping.
Here’s everything I’ve tried:
-Removed the battery
-Changed the power adapter
-Replaced the CMOS battery
-Changed the RAM.
But my laptop is still blinking. However, in the morning after I wake up, the laptop will turn on.
Here is my spec:
-i5 6300hq
-Gtx 950m
-Hp pavilion gaming 15-ak030tx Laptop DAX1PDMB8E0 Rev E
Now, I'm trying to fix the motherboard using the schematic I found
If anyone can help... - Loading...
