Help finding replacement buck ic for Sony XBR-65X930D
  • caphair
    • Nov 2011
    • 1249
    I know there was a recall for these TVs due to this ic failing so wanted to make sure I got a replacment that was revised? Unless Sony revised the entire board? In any way would like to just purchase the ic from a USA seller if someone could point me in right direction. Thanks in advance
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: Help finding replacement buck ic for Sony XBR-65X930D
    Tps54334
    • caphair
      • Nov 2011
      • 1249
      The same ic has again shorted out. Lasted about 8 months. Does anyone know why it keeps failing? I know it’s a known issue with this model. Anyway to prevent it shorting out again?
      • CapLeaker
        Leaking Member
        • 8326
        Does it run hot?
        • caphair
          • Nov 2011
          • 1249
          Does it run hot?
          Not sure honestly. Sony was replacing units for the ic failing so was wondering if they did a design revision or not. Should I put a dab of thermal compound on it as a precaution?
          • CapLeaker
            Leaking Member
            • 8326
            If heat killed it, I’d put on a heat sink, or look for a better spec’d replacement. Maybe poke around at the IC with an oscilloscope? I would have thought the buck converters are better than the LDO’s, but now I guess not?
            Check the voltage on input. It should handle up to 24V.
            • lti
              Sony MDR-IF245R transmitter LED replacement
              by lti
              I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
              06-28-2024, 01:47 PM
            • jm1234
              Reolink RLC-410-5MP - buck convertor
              by jm1234
              it's a PoE camera and it stopped working. Using thermal image I identified failing component U22 marked as 16AF which seems to be buck convertor TI https://www.alldatasheet.net/datashe...62569DBVR.html. I took it out and It is inteed shorted on the output. However, after I took it out, the resistance between the output pads (on the board) still shows 190ohm, is that bit low?
              Another issue is, seems to me I must be missing one of the tiny resistors R810 that should make up the voltage devider for the buck convertor. Honestly I did this months ago, I cannot...
              07-14-2025, 04:30 AM
            • timonix20
              Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
              by timonix20
              hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
              the TV starts, LG logo, then nothing (rear backlight)
              no reaction to rear command or infrared
              the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
              I have a chance with a usb procedure or other if you have .bin
              if any people have this main board
              thank you...
              04-23-2024, 01:52 PM
            • FZG
              Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
              by FZG
              Hello there, helpful forum people!
              I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
              On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
              The original part...
              05-10-2023, 11:54 AM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
