LG 55LN5700 reboots
  • sirentech
    • Apr 2021
    • 8
    LG 55LN5700 reboots
    Of course, worked great for a period of time! Before it could run for any period of time and then will reboot itself. It did not want to shut itself off a few times, so I had to pull the power plug. Now lucky to get 1 minute of video then reboots.
    Drops out too fast to get some voltage readings.
    Have worked on many brands before but not familiar with this problem from LG. Thinking either the BG soldered main chip is in need of reseating or perhaps an Eprom failure. Main board failure or entirely wrong-LEDS??
    Main chip doesn't get hot enough to shut it down.
    Have not dug into the LED driver yet or tested the strips with an external tester.
    Thank you for any help you may offer.
    I inadvertently sent this same post to the Capacitor forum. Sorry for the inconvenience.
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 55LN5700 reboots
    LN series suffers from backlight failures but they just shut down into protection mode since no error signal is sent to the main board. TV will be on with no backlight. If your supply voltages are stable, main board is suspect. Have not encountered BGA issues on this model either.
    • nomoresonys
      • 12330
      • U.S.
      can you post a good clear picture of each board and one of the whole back as to see how everything is connected.
      • nomoresonys
        • 12330
        • U.S.
        with tv unplugged from power, unhook cable from tcon to mainboard, leave it off, plug power cord back in, see if tv stays on, will be no picture of course.
        • bffargo
          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
          by bffargo
          LG 60PB66550 NOV 2014
          PSU: EAY63168603
          PCB: EAX65359531 2013.11.01 Rev:1.0
          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
          Symptom:
          While watching, just went black and started clicking relay every few seconds.
          Initial diagnosis:
          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
          Deeper diagnosis:
          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
          09-09-2022, 07:34 PM
        • sirentech
          Lg 55ln5700
          by sirentech
          Have not...
          10-30-2022, 01:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
